woody1986
mad as a box of frogs
Oct 21, 2008
106
Derbyshire
i Recently had the clutch cable changed on the car and it seems that since the work was done my washer motor has packed up. i checked the fuse but this is fine as the wipers still work and they are on the same fuse, i checked the jets were clear and the level of the screen wash. when the switch is pressed there is no noise from the washer jet motor which to me would suggest some kind of electrical issue. any help with this would be much appreciated
have you checked the plug on the washer pump hasnt been dislodged or broken? if you can jump the pump straight off the battery that would confirm if the pump is dead or not.
You ever get this sorted? Mines packed up too and fuse is fine and its too cold/dark for further investigation at the moment.
