Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Fen said:What I find scary is the possiblity of running out of water - if you are going to make it worth while having water injection (so it's not "just another safety net" as Ben puts it) then presumably the engine will go bang in a big way if it stops working for any reason.
Is there any fail-safe built in to the Aquamist systems to prevent that? What sort of quantity of water do you need for sensible boost levels (up to 1.5bar)? I think I'd want a water tank that could cope with at least a full tank of petrol, just to be safe but is that a big volume? From memory my washer bottle is 5 litres (and the petrol tank 80 litres) and if that isn't enough then getting something bigger in there would be a problem.
ryan_s3 said:I'm sure it's ok but fairly pricey.What systems do you have guys?
cuprabaz said:[ allow you to run different boost limit in 1st and 2nd gear... Ben
cuprabaz said:Not too sure mate but the guys i've spoken to who have used them say they are the best.
seen them on ebay for £250ish.
My local tuner has offered to fit and set one up on my car and if it works then i'll buy it. but it won't adjust fueling so i'm thinking no at the moment.
Glenn said:See in the attached Excel sheet (using real data from Bill's Oettinger chip) - if you plot duration, it looks like a torque curve. Likewise duty cycle looks like the power curve.
Mapping to injector duty is the correct way to map for boost and torque as peak injector duration (not duty) is at peak torque which is at peak V.E.
cuprabaz said:Just did some vag-com tests earlier just too see if the water/methanol injection had any effect on intake temps.
I did three runs with and three without, but i tested it on then off, on then off like that to make it fair.
Full throttle right the way through 2nd, 3rd and 4th.
Outside temp was 0.5 Degrees C,
Max Temp without WMI was 33 Degrees C
Max Temp with WMI was 24 degrees C
So i'd say that's a good result as far as i'm concerned. And not a waste of cash as many people think, that together with A&M's FMIC things should be nice and cool come summer.![]()
ibizacupra said:Interestingly, my Aquamist has contributed nothing since fitting larger FMIC... so in my opinion it is good for intercooler system which is'nt working well enough to beghin with... and my 1st test results & gains were with the std FMIC AM core. Not any more tho. Zero gain.
It would be a very good add on to std SMIC for people not wanting to hack things around to fit FMIC's, as it does work very well when it has a hot air charge to cool.
Its cold weather currently, so results will probably be better again when and if we get a summer.
To add, go onto the www.aquamist.co.uk forum and have a good read.. There's guys mixing nitromethane to their water/meth mixes and claiming big power gains.
