Water injection or Intercooler Spray?
Shock_Xe
Feel said:
Mike & Bill - it *should* work fine. The 3800/3900 might be "old" but they're good little units. It's a cheap enough solution (if you have a serial ODBII cable) to try it and see...
Edit: If you're both at Westec on the 3rd, get the software downloaded and installed and you can try my cable...
will do :cheers: :thumbup:
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Thinking about finally investing in a 1S.
Is it okay to use the standard water bottle? Along witht he standard liquid?
Or would i need to fill the bottle with only water/meth?
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
your washer fluid is made up of 25-50 % methanol/ethanol/isopropanol anyway so it'll be fine for the engine, all work as det control methanol being the best.
I found the wipers got shafted quicker(became brittle) with the 50/50 mix. lol :whistle:
Shock_Xe
personally im p8utting an alu water tank where the battery used to be, alu shouldnt conduct heat
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
dont forget the pump as to suck the water out of the tank.... and they advise pump is lower than tank for aided gravity fill...
