andicapped
well after doing all the work i did yesterday afternoon, i went out last night and...................................................
it's still
leaking, it's
wet through ![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
it's still
hi costa,
i've completely stripped the car this morning, outside and in. and left a hose pipe running (gently) on the windscreen.
i put a small amount of dye under the scuttle pannel where the water collects round the electrical box.(there's a reason for this)
the dye coloured the water under the scutle so if the leak was the i'd see green water coming through. well i left it for ages and ages, eventually it leaked and it was clear water, this was great news (sort of)
i narrowed done the leaking area to above the scuttle pannel, so it had to be round the window somewhere.
i then stripped the insde of the car and on the very righthand side at the back of the top part of the dash there is a large metal tube running horizontal. just behind and below it there is a vertical seal (slightly darker thsn the surrounding paint + metal.)
i left the hose running an watched it drip in from there. i've now sealed it so fingers crossed
hope that helps
hi mate,
yeah i've read your posts, i origionally couldn't find the leak as i beleive your leak was coming in above the accel pedal whee mine worked it's way along to the brake pedal. it seems that it's been leaking behind the carpet on the accel side and the excess was coming along and down above the brake pedal (behind the steering colum)
if this sorts it i'll be over the moon, even if it starts to leak again i'll know where it's coming from and it'll be a 5 min fix.
so fingers crossed![]()
Thought I'd add my two cents as I've just discovered soggy carpet in front and rear drivers' side footwells.. There were some droplets on the corner kickpanel immediately below the bonnet release, so does sound like it's a windscreen edge/fusebox (scuttle)/bulkhead leak... and to make both front and rear footwells totally waterlogged this must have been going on for some time.. (my windscreen completely ices over on the inside - this is what triggered the search)
Will report back with how I get on (bathing one's shoulders and hair in a soggy footwell?) Car is a 2005 LCR225, pretty disappointing to find a leak like this..I thought my 1995 Cavalier was bad for the leak in its boot, in 2004!
Alex
