alex_morley
Well that was a fun hour or so last night!
In the freezing cold of Manchester in the dark, I decided to remove the carpets so I can start to dry it all out (not loving the idea of water frozen to the inside of the windscreen like last year so want to get this sorted ASAP!).
I followed the basics of Marshy's directions (though mine was a bit more complex as I've got electric seats) and managed to get the front driver's seat, rear seat section behind the driver and all trim around the door-frame and footwells out on the driver's side.
I then realised that I've only ever had water in that side of the car, nothing in the passenger side at all as these were sealed up properly by the garage when I bought the car - why they only did that side I have no idea!
I decided therefore, to cheat! I carefully sliced the carpet along a natural lay-line and the same with the soundproofing so that I didn't have to remove the tunnel cladding, air con, radio, glovebox etc. I took out the offending SOAKED carpets (they literally ran with water for about half an hour). Some areas of the metal footwell were still about half an inch deep in water so I soaked this up with towels and am now trying to sort the best place for the carpet and soundproofing to dry out.
I've also ordered two crystal-based dehumidifiers to put in the car to try and soak up the moisture which is bound to still be in there while the carpets are drying in the shed/house.
I'll let you know how it goes and hopefully will have a clean, dry car soon!
Al
Al
