if it is that then im sure it just needs adjustment. main thing is its the easiest to remove and put back if it isnt that.
the cold air feed on mine isnt an exact fit so the vacuum never builds up enough. if yours is creating more suction it might be causing the squeak.
if the sound goes when you remove it pm luke on here.. they have fitted hundreds.
at least it rules out boost leak/tip issues if its the case
