What engine oil??
Lee Ainscough
9
Hi all. First post so sorry if it's not in correct place or if it's been covered. After a week of my leon cupra 290 been stood while away I've come back to find oil on my drive. It's booked in for an inspection with SEAT but my oil is low and was wondering if anyone knows what oil to put in. I've looked it up and I'm getting 0w 30 or 5w 30 castrol edge. Advise on other oil or correct oil would be appreciated. It only needs topping up!!
Sent from my SM-G935F using Tapatalk
Webstuff72
481
101
Milton keynes
504 for petrol and 507 for diesel (I believe). I use Mobil 1 Esp oil 5W30. This covers both diesel and petrol engines.... £37 on amazon for 5L....
weasley
137
South Oxfordshire
Yes, 504 00 is for petrol and 507 00 for diesel but they are always combined. Together these form the "long life 3" spec from VW, aimed at extended oil drain service in petrol and diesel.
502 00 and 505 00 are the equivalent in 'regular' oil drain interval.
Webstuff72
481
101
Milton keynes
Ok cool. Thanks for the info... How many miles is considered long life. I'm guessing regular oil drain is 10 000 - 12 000 miles.
weasley
137
South Oxfordshire
From memory standard drain is 15,000 km or 12 months. Extended drain is actually variable, where the car monitors your driving and how the engine is used and tells you when to get a service, which can go up to 30,000 km or 2 years.
Webstuff72
481
101
Milton keynes
Ok. Thanks again for info. I change mine every 15000 regardless and reset using obd11...
But i will now keep an eye on the service reminder screen and see how that goes down compared to my actual mileage. Just for #*its and giggles.....
Das Chin
210
12
Castrol edge 5w 30 full synth I think it is. match vw 504 or 507 if you want to buy a cheaper brand.
