I've got vag-com just going to see if any codes come up
I had a look for leaks but can't see anything obvious
dont T in from the dv......the dv needs all the vacuum it can get
this is the best place
or if like me you have removd the PCV all together i now use the take off point where the PCV valve hose used to go so my dv valve has its very own line
best place!
where did u take the hosing through to get to the gauge?
if you go under the scuttle panel where the ecu sits ,just to the right and back abit is a gromit
sorry mate but i dont have the car at the mo it in a garage at the mo due to haveing electric problems [:@]
other wise i would mate
its not hard to find,i think there i some wire going in to it as well
the bung i found is drivers side
and has like a cable coming out(carnt remeber if its the bonnet pop cable)?
is this the one?
