paul-murphys
efr 6758 here i come
i have done a search an read a lot of people are using the neuspeed rear arb an r32 front, i have read lots of people use the neuspeed rear arb because it clears the backbox. i have a aftermarket backbox so was wondering what else is available.
looked at these
http://www.awesome-gti.co.uk/product.php?xProd=11631&xSec=355
only 25mm i no but read a few people are also using 25mm neuspeed rear arb. has anyone brought this an if so what you think. for the money i would buy the neuspeed rear arb could buy front an back kw ones. ordered my uper strut today so will fit that as soon as comes in.
thanks for any inputs :D
8n04111305d is the 21mm version
1j0411305af is the 23mm version marked yellow
of the r32 arbs
n10101603 is the bolt
1jo411336d is the clip
1jo411314r is the mountin bush for 19mm
1jo411314t is the mounting bush for 21mm
You would have to be as thin as PTFE tape to try and slide underneath the back and unbolt and unclip from rear beam.
If you look in the FAQ section ruddmeister did a review on suspension and it shows a pic of rear ARB with car on ramps.
Then tell me if you think they would try and nick it
But he will then have a thicker front bar causing more understeer
I thought they should be fatter at the back or at least equal??
Didnt read it properly as i thought you went 23mm.
You could do 22 on hardest setting as you dont need a big fat 28mm bar with only 21mm up front.
A 25mm would be better as more adjustment should you want stiffer
I've got a 25mm neuspeed on the rear (stiffest setting) and just the standard arb on the front on my lcr and it is a nice handling setup :)
