The hybrid treament certainly helps but not as much as you may think, my advise to make a noticeble difference to your set up is:-hey you got a nice torque curve there !!
i have a question do you might know how its done to hold it that long ?
mine has a peak at 3k ish en then 4.5k already starts to drop
so i was wondering if u might know what would help against that dropping...?
(my graph is found here : http://album.partyflock.nl/73502004.jpg )
!. Large Jetex air filter with decent cold air feed.
2. Descreen the Maff.
3. Custom 3 inch intake pipework ( bin that pee shooter)
4. Forge uprated actuator
5. Forge Unos mbc in place of n75 valve.
The above will hold your torque a lot better, minor fuel tweaks may be required.
spool, waaarrrppp, cough, splutter, BANG *as it spits the turbo through the bonnet*
