Its well over due for me to put a readers ride together about my pride & joy. I've enjoyed so much reading about the good things the rest of you have done i'll try and put a bit back with the experiences i've had with my motor and if it helps anyone then great.
I bought the car new in September 03. The car is slightly unusual in that i was told it was the last of the 210hp's to be registered and hence it is registered as a 53 plate when at that time the first of the 225's were turning up.
Modifications to date:-
Revo Stage 2
Hybrid K04 c/w Forge actuator
Blueflame turbo back exhaust complete with 100cpi cat
Proalloy race intercooler
Forge 007P DV
Jetex 8001 Air Filter
Custom 3 inch tip
Custom MOFO Maff housing
Turbosmart Eboost Street Boost Controller
Powerflex dogbone mount
Falken 453 tyres
Devils own wmi
Genesis 550 injectors.
IE Conrods.
Relentless V2 manifold with Badger5 reinforced welds
Neuspeed 25mm front arb
Neuspeed 28mm rear arb
Sachs performance clutch
Quaife LSD
Superpro wisbone bushes
Bilstein B12 Suspension.
To Fit / Desired Modifications
S3 Strut Brace
Badger 5 torque intervention removal upgrade
Winscreen wiper mod
THS fr3 engine mounts
SEM Intake manifold
Engine bay silicon replacements
Audi TT Short shifter
Big knob.
Shifter bracket bushings verdict motor sport
draft 42 gear shift bushings
Rear Strut Brace
Hammerite Subframe.
RBF 600 brake fluid
DS2500 pads
Revo Stage 2
Forge 007P DV
Custom 3 inch tip
Falken 453 tyres
Devils own wmi
IE Conrods.
Quaife LSD
S3 Strut Brace
Winscreen wiper mod
SEM Intake manifold
Big knob.
Rear Strut Brace
Hammerite Subframe.
RBF 600 brake fluid
DS2500 pads
The torque is still there at 6.5k rpm.![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
