December
239
Cluj-Napoca, North Romania
Recently i've noticed there's something wrong with my window on the drivers door.
As you know it's got 4 functions: 1. all the way up; 2. Slowly upwards; 3. Slowly downwards and 4. All the way down.
Now the problem is with #3 ... it seems to be a little laggy; i have to keep it pressed down for a few good seconds before it'll actually start moving downwards.
Has anyone had this problem ? How do i fix it ?
aaaaaaaaaaaaahaaaaaaa !!!!!!!! i figured it out.... >_<; oh and btw my window doesnt go down at all anymore on the #3 position.
Try this: Grab the button with your thumb and index finger and push it in position #3... if nothing happens then push a little more without going into position #4 ....
You might find out that the window will start moving downwards at once.
So obviously there's something wrong with it; the #3 position and the connector that makes the window go down are out of "sync" they don't touch on the #3 position anylonger... but a little lower between #3 and #4.
Mine does the same - I put it down to a dry joint/wear in the switch.
I'll try a new switch and report back.
