These bits may come in handy...
Bits for the glovebox light:
3B0 947 415 B Glovebox Lamp [email protected]
1J0 947 561 C Switch [email protected]
893 971 632 Housing [email protected]
1J0 973 119 Housing [email protected]
000 979 133 Cable [email protected]
000 979 131 Cable [email protected]
Bits for the boot light:
1M0 947 101 A Boot Lamp [email protected]
6L6 867 761 F Shelf [email protected] replaces existing shelf.
1J0 971 972 Housing [email protected]
000 979 131 Crimps Included in the above for glovebox
Parts list above includes all connectors, crimps and other bits to make the job the same as the OE installation. All you need is about 3m or so of 24/0.2 equipment wire such as:
Maplin order code:BA40T 10m Red 24/0.2 [email protected] clicky
Fitting Glovebox light:
Connect the glovebox light and switch in series and mount in the existing cutouts on the glovebox.
Connect one end to red/black wire on the interior light
Connect the other end to GND (bare metal bracket to the left of the glovebox is ideal)
If the light fails to illuminate when the glovebox is open the reverse the two wires going into the bulb holder. This is due to the bulb holder having a diode fitted making it polarised.
Fitting Boot light:
Replace existing rear passenger side shelf with the new one.
Pull back the carpet below where the new shelf is mounted in the boot.
Connect one end of the boot light bulb holder to the brown/blue wire in the pink connector.
Connect the other end to the red/black wire on the interior light.
If you have any problems post up and ill try and help, if you burn your car to the ground its not my problem though
Fitting Boot light:
just noticed the prices next to every part
