Hi could you run down the spec of the engine, I've had my engine back a couple of weeks now built by RPM
Full ported by Jim
resized rods
Je 12.5:1 Pistons (lightened & balanced)
Newman 288 cams
Competition bearings
Lightened Flywheel
ARP Bolts
Lightened crank
Port matched Dbilas inlet manifold
Dbilas Vernier
Dbilas Inlet Vernier
Twin 45's
Going for rolling road on Friday @ BD Engineering
Any ideas on BHP.
Badger 5 DTH Throttlebodie Conversion
DTA EXP38 ECU
RPM 275 Cams
Piper Vernier Pulley & Inlet Cam Sprocket Vernier
RPM Gasflowed & Ported Head, Injector reccesses filled, mod'd combustion chambers, matched ported to TB's
ITG Megaflow 'Domed' Foam Filter
80mm trumpets
20vt Fuelrail, Injectors & 3 BAR FPR
Renualt Laguna Coilpack(?)
Ford Crank Trigger
AC pump, Rad & Pipes Removed
VW Mk3 Golf 2.0 8v Alternator & Bracket
Windage tray
Shrick Baffeld Sump
TSR 4-1 Manifold
2.5" Jetex 100 Cel Sports cat
2.5" Jetex Cordoba Cupra 20vt Exhuast
whats the size of the 16v?
9A 2.0 Oh it has a Magnex four branch with Omp Gp A Two box system.
Full ported by Jim
resized rods
Newman 288 cams
Lightened Flywheel
ARP Bolts
Lightened crank
Dbilas Vernier
Twin 45's
Any ideas on BHP.
If they haven't told you what BHP you will get, I would pay them no money
Hmm they said they would be disapointed at anything under 210. What do you think.
I think with the hike in CR you should get this easy - I have seen similar spec engines do 215 on 45's
what size are pistons ? (are you above 2L now)
I've kept it 1998cc as i don't like to cheat in the sprint Mod Prod class.
dont think even that will help mork on sunday it set a mk3 cupra alarm off just blipping the throttle, sounds ace.
