suppose your right! maybe i am worrying and i didnt have any doubts about it till i read some feedback maybe i shouldnt read themcheers again
not very good feedback on the IHI (sorry to keep banging on!) but have i spent 5k on a mickey mouse turbo?
Bill, what torque (and when) were you peaking at 1.2bar? I'm considering no more than 1.4, but maybe 1.2 would be enough....
Raf
Nope its not a micky mouse turbo at all.
If you have been reading and understanding the posts you will be hearing the message of keep the levels sensible and the things run fine.
Want more, get the speed bug bad, and turn it up, and then you eat into the margins of reliability.
If you get a real 320bhp when done, in an ibiza it will be a rocket ship with performance like you wont believe is possible from your car. Trust me.. you will have big smiles.
Understanding the failure mechanisms of these things in a long way to avoiding failures. CC will map for lower EGT's, and typically run them richer than I saw my own JS mapped car. Maybe not best for LBT but better for longeveity especially on IHI exhaust housings.
Probably the best my motor ever ran, and performance times for it were when it was first originally done, with 320bhp. 1.2bar, happy as larry and ragged rotten. I wanted more, had it turned up, and consumed several IHI bits and pieces from there on in until I changed for a completely new setup of my own making.
Enjoy![]()
Does any one know what the small end pin size is on my con rods. I know it was mentioned a while back in this thread and i am assuming they are 20mm. But could anyone clarify this as some are saying 19mm and some 20mm. The engine code is BAM.
20mm mate![]()
Older 1.8T engines are 19mm
I hope my BAM has 20mm as I have the rods ready to go in
Been told now by several people inc Bob Quindazzi (QED), Jabba, that the BAM has 20mm small end pin. Its put my mind at rest and i can now order my rods. Thanks everyone!![]()
Scats? did you order from bob?
