Phil_beeza
461
i see what rash cupra has done, there is a flap which blocks half the entrance of the intake.
just waiting for seat to get back to me on how much this part is.
i feel the need to open it up, but in case something goes wrong i need to be able to replace it :p
has anyone with a 100bhp tdi chopped this bit off? or anyone offer info about the MAF error?
it seems pretty easy to know where to cut it, basically on the sloped bit that's slanting down? (yeah my pic was up side down!) just wondered about getting problems if i open the gap up.
vw have just told me this part is £5 inc vat and p&p, so i might just chop away!
just karv it off :thumbup: modifying the intake wont mess your engine up modifying the maf housing ect is when you will hit problems
dis maf housing....whats maf stand for? something air filter?
maf is the box the pd160 goes into, rite?....
lol can i get a guarantee from u about that ;)
i took the flap off mine, it wont make any difference what so ever to the MAF as for:
1. its nowhere near it anyway.
2. its a bit of plastic, its only like chopping a hole in the grill.
more air generally=good ?
also if i do all this stuff is it going to make my fuel consumption go up or down
so I'm expecting a slight increase in performance as well
fair nuff...im still slightly gutted that going from 195 to 215 tyres, my av fuel cons. has gone frmo 45 to 41 (so far on a continuing average).
didn't figure that into the purchase.... :p
I've gone completely different to everyone else got an adaptor that covers the intake at the front of the car, that that as a 76mm diameter connector that conects to my air feed pipe the to a 45 degree silicone tube that conects to my dynatwist.
If this helps?
Obviously this is if you go for a dynatwist.
i've chopped half an inch off the flap, to see what happens :p
rash did you seal up the horizontal 1/2 inch strip of open air at the bottom of the intake pipe adaptor?
is this supposed to feed a small jet of cold air to the rest of the engine or something?
Well I fitted my Cupra air intake yesterday. Straightforward enough once it's manoeuvred (horrible word to spell! :yes:) in place, and had the same problem as some others in that there is a small water hose resting on the intake pipe. Manage to tie this out of the way (without actually rerouting it), but it still rubs so it out with the grease. Don't do a big mileage anyway so will keep an eye on things.
While I was fitting it also decided to remove the flap completely. Out with the junior hacksaw, Stanley knife and file. As long as you're careful and patient it's easily done. Doubt I will bother with a strut brace because this will probably mean more cleaning of the air filter (no flap might let the odd sparrow through now!:lol:).
Already have Green panel filter so it's all ready for a remap. Watch this space!:p
Hi All,
I cut the flap right out and sealed the gap and havent had any probs in 3 months,
Yella Bezza, strut brace is worth it mate does help especially if your on standard suspension and it only take 1 min or less to take it off lol also makes the engine bay look nicer :p
