Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,569
Nr Milton Keynes
Here are the correct part numbers for the rear Skoda Fabia Wiper.
6Y6 955 435 - Hatch Back Cap
6Y0 955 425 - Wiper Blade
6Y9 955 707 A - Estate Rear wiper arm
You use the Estate wiper arm because it is longer.
Takes 5 mins to do.
1) Flip old cap off.
2) Undo the 13mm nut.
3) Wiggle till old wiper is off.
4) Put new wiper on and do the nut up (not to tight)
Little tip is to put the wiper on so the end tip is touching the paintwork. Then after your first wipe its should level out.
Hope this helps
Here are some pics.
Ok so now i know where i was going wong..
Your all going to :roflmao:
I was spelling wiper as "whiper" hence no search results.. I can find loads now :p
Sorry all!!! :ban:
Wow, those are almost exactly the same numbers as the ones in Icecavern's original post from 2003.
And by "almost exactly" I mean "exactly."
Not quite exactly I'm afraid.
Icecavern quoted the following for the arm:
Wiper arm - 6Y6955704 might be superseded by 6Y6955707A
The correct part number for the arm is 6Y9955707A
Good to see mine was £2.50 cheaper in 2006 than 2003 :)
I have considered making up part numbers when it's asked now, I mean a 2 minute search will pop up about 50 threads with these numbers in I'd think.
I have to say I've never used the part numbers, like you say I just go in and ask for the parts and they sort it out.
excellent, cheers, i know according to everyone there are already posts up but the pic and quick walk through is rly helpful.
tnks:thumbup:
