TDC
71
Cupras sold & been replaced by a damaged TDI SE in same year & colour !!
Its gone up onto a post & wiped out the following -
sump
n/s wishbone & bolts
front subframe
engine stabilisor bar & mountings / bolts (lower back of engine to subframe)
n/s/r light
n/s/f fog lamp surround
front bumper
n/s/f headlight
Both airbags & belt tensioners
Engines flopping aboout a bit so may need the other (2 ?) mounts
Noisy , sounds like exhaust is blowing so need to investigate that 1st.
& looking for a lowering advice ( can i just fit cupra springs ? )
Also need a mintish set of TT or S3 alloys (17inch)
Any ideas on a good source of used parts ?, i have emailed the 2 ebayers that are breaking Leons a day back but no replies yet.....
Yep maybe, the rims a little damaged & wheel is back an inch however it was hit square on the front wishbone mount so looks like that & the subframe took 90% of the force.. i want to lower it anyway so may get a set of used struts....
Chassis looks OK , i will measure it all once its stripped..
<IMG SRC="http://usera.imagecave.com/vikbaker0/leontdi/leontdi005.jpg">
A better one... <IMG SRC="http://usera.imagecave.com/vikbaker0/leontdi/leontdi005.jpg">
point of impact to the left.. <IMG SRC="http://usera.imagecave.com/vikbaker0/leontdi/leontdi007.jpg">
<a href="http://usera.imagecave.com/vikbaker0/leontdi/leontdi005.jpg"><img src="http://usera.imagecave.com/vikbaker0/leontdi/icth_leontdi005.jpg.jpg"></a>
Let me know if you need these, I have a spare set of springs from an 02 Cupra.
i got full sus to if needed goto replace my hub as i had an accident mainly subframe but no hub bent to and you wont noitce it until you get 4 wheel laser and alignment tracking done
Thanks Hoff, but im sorry i dont understand your english properly..
Here goes & please correct me where needed -
1 - you have a full set of suspension available
2 - I may need a hub ?
3 - I wont know if i need a hub until i do a laser check ?
Martin
If the exhaust is blowing on the Downpipe it's a good excuse to put a new DP on, if it's cracked on the longer straight section under the car or the cat is knackered ... just replace it with straight pipe - no closed loop emissions / lambda sensors on a Tdi ;)
Martin
Yes i have suspension for sale if it fits then you can have it for £50
Yes hub may not be found until you do alignment and something else may come up its hard to tell until you do the above really
Cheers Hoff , 50 quid sounds great, :) what do you have exactly ? springs or struts etc ??
Fester Man , yes... a great excuse for a decat, is it correct that theres no lambda in the cat / downpipe ? if so the MIL wont come on then ?
Virtually all parts sourced now apart from an FR front bumper , a decat pipe & plastic engine cover & rear window switches. .
Tried"motors in motion" last as their ebay ad looked expensive but they were quite reasonable & professional.. got most of it though from............Fenland Breakers - they were cheap ! - airbag kit , subframe & wishbone for £210 delivered !
Need
FR Bumper
Decat
Rear window switches
Plastic centre splash guard
Wish List - FMIC
