a11y
2 wheels better...
Jul 18, 2007
298
Central Scotland
Shiiit!
If I had adjustable suspension I'd blame that on too much negative camber (i.e. front wheels form an "A" shape when viewed from the front) but there's no way to adjust the camber on mine (standard SEAT suspension).
Any ideas folks?
Only had the car 3 weeks and just noticed this last night (I know, should've checked better...)
Ally
Mine did this to its first set of tires! How many miles have you done?? Have heard that its due to various different things! Do a search, you will finds lots of threads on this subject mate! :(
mine does the same spose best bet is to get non directional tyres and swap them around to get the most out of all your tyres but sinse i put my coilovers on and ajusted the tracking at work it doesnt wear half as bad anymore or pull left that much!
I want to get mine done by a proper alignment place, where they can do camber, castor etc, etc! Nowhere near me that has the gear to do it all properly, just the usual laser alignment places!!! :(
Cheers,
dozza - noticed your comments in another thread too, cheers.
Not sure how many miles have been done on this set of tyres (i've done about 900 miles in the past 3 weeks since collecting it though). It's currently on 25k miles on it's second set of Pirelli's according to the last owner.
I'm just debating what tyres to go for. I certainly won't be going down the coilover route again (not worth the expense for my driving) so don't think I'l be able to have much adjustment of the camber, etc. I didn't think much could be adjusted on a standard suspension set up?
Toyo T1R's or Proxes4's are both excellent in both the wet and the dry, and cheap if you go to the right place, Goodyear Eagle F1 GSD3's are also superb! I got mine off ere, cheapest place on tinterweb! VVVV
http://www.camskill.co.uk/products.php?plid=m4b0s13p0
i ordered 4 T1R's from this place - £220ish based on advice from here! couldnt find them cheaper anywhere else, hopefully get them fitted at the weekend n give them a wee test!
Just a thought - have you got worn bushes on your front wishbone.
You may be getting that wear pattern due to excessive play during braking.
I had the same but to a lesser degree and took the opportunity to install poly bushes:)
dozza, cuprakel: that's where I'm looking, although I'm thinking about the Toyo Proxes 4's, possbily in 215/40/17 rather than the standard 205/40/17. Certainly the cheapest for Toyo's by a long way.
Orcam0ng: I'd hope not at only 25k miles, but I'll have it checked out when I'm getting the new tyres fitted and set up.
All the cars that come into our work are like that, and unfortunately its down to the speedhumps round our way...we have them square ones with the sloped edges rather than the traditional one across the whole road type.
Nothing you can do about it, other than buy cheap tyres or avoid speedhumps.
speed humps wont wear down tyres this much me thinks!!!! its the non ajustable camber caster settings only adjustment you can get on ibiza's are on the subframe bolts the lower arm bolts the strut to knuckle bolts and this is very limited tho
Do you live in Northampton? Do you see the cars that come into my workshop? No, so you're not knocking my comments back!
Before the speedhumps were installed round here, we only had the odd car with uneven tyre wear, now we see it all the time. Two manufacturers I have worked for will refuse to pay warranty claims relating to uneven tyre wear for this very reason. We fit tyres and get them 4 wheel aligned and guess what...they're exactly the same in 12 months.
so you mean the speed humps knock the wheel alignment out
no need to get all emotional and defensive im only stating my comment as we have loads of speed hump near where i work and i dont see this problem in my garage ;)
My cupra fronts inside edges were bald after 14k with about 4mm left on the outside (apparently 14k is quite good compared to others on here). Seat obviously wont do anything under warranty, but I wrote a letter to show my disappointment.
So I just got the full Hunter geometry set up by Elite in Essex. Camber was well within tolerance (slightly negative on both sides) which I chose to leave alone as I didn't want to bring it in to zero camber. And the toe was also ok. In fact the toe was slighlty out on the tyre which was in better condition, so I had the toe brought into its limit on both sides.
I don't expect to get any better wear out of the new GSD3s but hopefully rotating front to back should help a bit this time.
I rotated front to back on my last set of tyres and still only managed to get a bout 12k miles out of them, that did include a few laps around the nurburgring tho!! :lol:
