Yeh, 1.8 for bout half a second? then sitting about 1.6 bar tops?
Yes, that's about right, falling to 1.1 at the redline. Peak power is usually at 5,500 where you should see a smidge under 1.2 bar.
And yes, standard boost is 0.8 bar.
Phil
any stage 1 remaps use the 4 bar fpr?
Phil
As I understand it though, when it's runnign above the MAP's maximum, it falls back to using the IAT and the MAF to calculate the boost. Probably explains why a duff MAF on a chipped motor is extremely noticeable...Not as far as I know.
I'm a bit confused by your question though...
Edit: oh, I get you now. It says 4 bar fpr in his sig. @OP - you should take that off, probably an idea to read up on A/F logging just to be sure, but nobody does a Generic Stage 1 map that needs a 4 bar fpr AFAIK.
