Coilovers fitted
Riko
MURDER WAGON
Jun 10, 2007
1,481
Milton Keynes
Coil Spring compressor @ Halfords is £19.99 to be exact! Bought one a few weeks ago. Made by 'Laser' i think?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
cool ill bear that in mind, had a thought the lad im doing it with works at a ford dealership so i would assume he would be able to get some.
Oct 31, 2006
870
Cambs
i didn't use any one mine neither, you might want to get new top mounts and bearings, make sense if your taking it apart anyway.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
yeh already have all mounts front and rear and new bearing sat in my bedroom, just need the bloody coilovers now!
Oct 31, 2006
870
Cambs
they will arrive mate, having said that mine took a little over a week to come from germany!!
the only thing a found was the black caps on the front top mounts in the engine bay were a nightmare to get off, i resulted to cutting them off as they were not going to fit back on!
Nov 2, 2004
9,335
South Wales
Just buy new top mounts and bearings then you dont have to touch that large nut on the top, just drop the suspension out after undoing the 2 17mm on the hub and the 3 12mm? on the top mount. Just falls out.
Dont know what the fuss is about.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
mine should be fairly easy then as i have all new mounts and bearings. Aslong as the nuts and bolts all come undone ok...
I wont be needed spring compressors then?
Bing_17
nope u wont need them m8, your old strut will come out as 1, and if youve got new top mounts u dont need to get to the old ones do u.. so no compressors needed..
Car lookin schweet btw elliot, canne wait 2 see it again! infact, cant wait 2 get mine lol[B)]
Fitted LCR splitter.....and the coilys have settled a bit more :D
Bit low then ;)
