is the conversion worth it and will it fit behind the cupra 17's?
Been offered calipers, carriers, disks, pads and hoses for £150
I never did it to mine but have heard good reports from people who did it.
It will fit behind the wheels no problems as Derv & Petrol have the same wheels.
OE caliper on a 288 standard carrier means 288mm discs. Put the larger carrier on with the same caliper and you're able to run 312mm discs. Only thing you technically need are discs and carriers - fitting new pads at the same time is a good idea though.
