Blimey they are smooth curves, I would have to polish my carpet slippers before I drove that, I think the computer that generated it smoothed out all the little peaks & troughs, or you need to get your 4 pot in the guiness book of records for smoothness, a prime example of a slightly constructive example of a power / torque curve!![]()
Hi guys, I have couple questions on you.
1) whos got remap on new cupra and what power you have got???
2) does anybody have remap plus full milltek system???
I just got back from dyno, my car has a remap and full milltek system and results are terrible, I am very dissepointed, only 283ps and 388nm
is it normal?????????????????
How does the 'butt dyno' feel? Bit quicker or lots quicker?
Did you do a before and after run on the same rollers? If so what results did you get.
Do you know anyone with a standard non-remapped Cupra who has been on the same rolling road to compare results to.
I'd suggest without any real control figures, the figures that the RR has gave you, really mean diddly squat.
here is the graf from yesterday:
Hi Tommycupra,
If you ran alone on the RR it doesnt mean a lot as the rollers on the day and the conditions can give dramatically different results. If you can compare to someone elses expectations or a before & after on your own vehicle then you have a relative gauge. In real terms, how did it feel afer the upgrade? A grin factor hike in power, you have a result, the figures are erelevant without a comparison.![]()
Hi, when we put back the ECU and install milltek, car was faster, but not too much like I thought it will be. I cant compare, becose nobody have same mode like I have here.
zboyd your to fast on my english, what is butt dyno feel???.
Hi Guys
I am afraid the old ''Dyno lottery'' may be coming into play a little here.
I have 11 of these models running the P-Torque re-map now, and out of the those who had a Dyno run, between 304bhp and 319bhp has been made (without exhaust system)
Have you changed your DV? These split on the Cupra models and will reduce your boost.
Send me some VAG-COM logs. I will e-mail you how to do this![]()
