I got fed up with rolling round corners like an overloaded tramp steamer and after seeing deathead's mint mk1
on coilovers I bit the bullet and ordered up a set of TA Technix on eBay, same as his. Great price and the build
quality seems good. They arrived Tuesday afternoon and I tore into it. Much swearing and knuckle bashing
later they were in and this is the result. I dropped the back as low as it would go and moved the adjusters on
the front up so that 40 threads were visible on each side without the locking ring.
A word of warning if you are thinking of doing this yourself! The standard scissor jack is no longer safe to use
at the back as the suspension is now so stiff that when u jack up the back of the car, the whole back end comes
off the ground. I found this out the hard way when the car slowly toppled to one side, landing on the floor. I
was only using the sciscor jack because i needed the trolley jack to lift the hub and damper up into the tower
to attach the top nut. Use axle stands!
Oh and the wheel centres finally arrived from der deutschland
Before:
After:
Before:
After:
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
