Torquemadder
Jaded old petrolhead
Jun 4, 2008
51
Lisburn, Northern Ireland
I got fed up with rolling round corners like an overloaded tramp steamer and after seeing deathead's mint mk1
on coilovers I bit the bullet and ordered up a set of TA Technix on eBay, same as his. Great price and the build
quality seems good. They arrived Tuesday afternoon and I tore into it. Much swearing and knuckle bashing
later they were in and this is the result. I dropped the back as low as it would go and moved the adjusters on
the front up so that 40 threads were visible on each side without the locking ring.
A word of warning if you are thinking of doing this yourself! The standard scissor jack is no longer safe to use
at the back as the suspension is now so stiff that when u jack up the back of the car, the whole back end comes
off the ground. I found this out the hard way when the car slowly toppled to one side, landing on the floor. I
was only using the sciscor jack because i needed the trolley jack to lift the hub and damper up into the tower
to attach the top nut. Use axle stands! :D
Oh and the wheel centres finally arrived from der deutschland :D
Before:
After: :funk:
Looks well, lovely clean car. Wind the damn things down and get those rear adjusters out:p:whistle:
ps - get your butt up the sprucefield every 2nd monday of each month, wee need more Arosa's there. Mine was only one there monday past. Youve no excuses, your beside it ;). Im trying to start an Arosa revolution [B)]
Itll go this low on the back with rear adjusters out, and its well wound down on the front too -
Got this wee pic took of mine on monday night at sprucefield, was a good nights craic but badly need more arosa's
Omg you're from norn iron? Dude! I'll be there lol. What time?
I'm waitin to see how it looks when the springs have settled in a while before I drop it any more. Plus I dont want to go too low and ruin the handling :redface:
Oh yeah an I'm gettin fed up payin Kwik fit to adjust my tracking! :D
I've had it done twice in 2 weeks. First after I fitted new track rod ends and again after fitting the coilies
People start gathering about 8 o'clock. Be there about half prob. I can guarantee you'll have those rear adjusters out in less than a week lol. Slam it
any more plans for it then
I want a Jetex centre exit zorst and a more free flowing air filter. Not sure yet wheither to get an induction kit and box it or just mod the standard airbox.
I have a Blitz front mount intercooler lying in the garage just begging to be fitted but i'll need to measure up and get hard pipes and silicon joiners ordered first. If I do all that I can have the boost turned up a bit more ;)
I'd like 125bhp and 200lb/ft :p
