in depth yes i didnt set mine up but you can set 2 settings on my one low and high boost etc
off here for 120 quid lol
under the steering wheel to the right hand side theres a little cubbie hole stuck it to that and yes 2 cables and a vac pipe for it
You may find it takes a while to get the mbc set right as it can be a very fine line. How have you got it plumbed in? Also what is your actuator pressure?
just ordered the Greddy spec B II, so will get that fitted asap
Will your Forge Unos be needing a new home......![]()
Oh yeah, take a look at this for getting started with setting up the profec --> http://www.elitedubs.com/index.php/topic,741.0.html
got it plumbed in off the two of the lines to the N75, will try and get some pics up
Yeah get a pic up. Is its got three lines yes? In, exhaust and atmosphere.
Dont quite understand why you have just gone and got an ebc when you dont even know A-if its set up right and B-if boost control is actually your problem.
Also how much adjustment has the mbc got on it. What is the distance difference between fully wound out and totally closed?
I assume full wound in would be running off the WG spring pressure.
