Fl@pper
Jun 19, 2001
12,366
24
Gloucester
Anyone using the lower gauge pod (mines a lhd one)
just wondering what gauges you are using as the ones i have just been given the surround is too big and the trim won't fit over em :(:(
probably just as well as they are a bit kevish :headhurt:
what the cupra 2 gauge holder? im running that one also lhd and running the original voltmeter and oil presssure gauges.
ye thats the bugger
got a couple of dummy (1974) alfa romeo ones in mine so a mate gave me some brand new (ct racing -ye ok i know) that fit fine but stand too proud to get the trim panel over
mind you it was only £6 or so i might just shape em out to suit instead as the gauges were free anyway
btw crezz - if you haven't planned it already get a mk3 cupra stg wheel on ya list - best mod yet on mine i swear - lusssssshhhh!!
Oil pressure and volts gauge (when I finially wire them in) got a volt gauge to keep an eye on my racing battery :)
is the lhd gauge holder hard to fit nicely?
where can you get them from?
is it easy to connet them to the cars engine/electrics?
cheers
i also want a mk3 steering wheel
it fits but to be honest it's a little low on the LH side and angles awkward so some clever suppourt under it (nut and bolt) is adviseable
ordered all my pieces from the dealer for about £30 odd iirc if not less than that i'm sure
wiring gauges is easy as for any gauge depends on what ya got but steer clear of any with a fat lipped surround as they wont go under the front fascia
as for steering wheel you get a similar effect if you remove the upper weight out the std wheel as the mk3 is lighter but it has a wider F-R girth and only 3 spokes and a huge centre all in one horn that once on you will never go back - gotta be the best mod i have done
ill try an post a pic up
nothing is available from dealers anymore except the oil pressure sender/switch you need to run standard dials.. that was £5=vat iirc............look on ebay.de...dont ask what to type in.. i searched all parts that included 'ibiza' in every day for going on 7 months.. easier to make your own fascia to fit the rhd bowl and use your own dials from demon tweaks ect
Would you say that for wiring up a rev counter gauge?? Because I have one that I am thinking of fitting as my 1.4 doesnt have one,it has a clock instead. And I quite fancy a stand-alone one.
All you're likely to need to drive a standalone tachometer is a +ve power feed, an earth and a signal. Where you get the power and earth from will largely depend on where you fit said gauge, and you should be able to source the signal from the low voltage side of the coil.
as G says probably the simplest gauge to wire up in all honesty
reminds me i was meant to check which coil wire you needed - ooops :redface: brb
*edit* Jeezus it's cold out there :p
Green/Red centre wire (coil connector)
mine's rigged up to that but check ya wiring block at the back of the speedo - might be prewired
Its going to be fitted on the A-pillar in a pillar mount. So where should I take the power from and make the earth??
It will need wired up to the lights (I think) as its one of those gauges that is dark until it is powered up. I know theres a picture somewhere.
I was thinking that it may be pre-wired as the when you switch gauges for one with a tacho they work straight away. Will the wire still be green/red behind the speedo??
So its the centre wire on the coil connector, Im guessing its both green and red.
Take your power feed from anything convenient around there that has a power feed switched by ignition, should be fine and dandy. You probably don't want it wired down to a permanent feed as it'll be a constant drain on the battery (albeit a small one). Just occurred to me that you may also want to run a switched lighting feed up there if it's an old skool type gauge and you want to be able to see it when it's dark.
I was going to wire it up to the headlight switch so that it comes on when the side lights or headlights are on. I will have to find out where I can take a power feed from.
There will be plenty of earths around there. The tacho gauge I have has 6 wires coming from it, 3 thick ones and 3 thinner ones.
for illumination there's a light switch underneath and for the rest the fusebox is right under that :p
wouldn't surprise me at all to see it prewired behind the dash and yes it should be green/red stripe all the way
Its the same type of gauge that Surcalation has in his mk2. The ones that you are only able to see the numbers etc when the ignition is on.
So Im guessing a one of the thick red wires will be the main power, i.e from the fues box and the black will be the main earth. and the thinner red will be to the ignition and the other black will be for another earth. That means I'm left with a green and orange wire, one will be for the signal from the coil and the other for illumination. How should I wire it for illumination, to sidelights or headlights or both??
