Does any one know if i can replace the springs on my weitec shocks to get it to drop further? If so what springs should i look for?
what insurance company did u go with?? ive got 2yncb and mine is £2000 fully comp!! and by the way ive gt the seat centre caps, they look gd
Rear wheels always camber ever so slightly due to weight however if it is noticeable then you will need to get it checked out. Is the wheel sitting flush to the hub and the alloy? Have you had full alignment done since your suspension upgrade?Just noticed today that the rear spacers are making the tyres camber so that the top of the wheel comes in, on the bottom is slightly kicked out. Is this common and can i get it so it sits straight by the garage?
Yea they would have aligned it definitely. Check your tyre pressure, should be around 32-33.Yours the hub is fine its noticed sinse i put the spacers on. It's not in your face but i can see that ill get uneven wear. i think amd aligned the wheels after puttin on the suspesion kit mayb it needs to be done again if you put spacers on?
I don't think there is anything to worry about. Like i said that it is normal and I have it on my previous set of tyres (Eagle F1s).
If they are going to drop it further then they will do alignment again.Thats good then, it's going back into Amd to get an additional 20mm drop as i wasn't happy with the drop i got. they will be able to straighten it out or tell me it's fine.
Got the suspension sorted out. The original weitec kit i bought had the wrong springs so Amd ordered a new kit and the car was lowered properly today! looking the part now i think.
yes definetly
Very very nice!![]()
Thanks, im going to get some more pics when the car is clean, im definately happy with the drop now... next up S3 interior
i thort you might! It is the best interior mate
