there r a Golf mk1 2.0 8v NA that go for 1/4 mile in 12.32 seconds
Looks very smart that Aaron - surprised you didn't use grey leather for the boot install though - maybe get a matching 'R' logo stitched into it.
You're making me want to do something with mine now and I really need to see you about that battery move :)
I thought he was NA, i didnt look up, um so lazy :D
:cartman:
GREY!!! you mean black mate :) and i have it i just need to make the boards.
what gauge cable do you have runnning your amps? im sure you have 4 it should be an easy job for you... not that running a cable in takes time.
:cartman:
I'm colourblind :p
I think it's 4 gauge, may well be 0 gauge - it's as thick as my thumb if that helps - not sure if the derv will require beefier cable due to being a bigger battery and a higher cranking requirement than your 2 stroke petrol engine :p
um yarp you might be right there... i forgot about the sootyness.
i had an hour and a half of jump starting last night, only to find a bad earth... why work for a couple of weeks then decide not to. bloody cars
Agreed they're a pain in the neck most of the time, same as computers, 14 hours straight on friday night and no progress ... an hour spent on saturday morning and had it all cracked and up and running.
i would like to have a look through them, will be an interesting read.
Screw you.. I didn't say anything cause it might be true.. If it is you can suck me off for calling me a whimp! :clap:
Also i forgot to take measurements :( If you could just get me a 4"x1" sheet that would be great! Thick enough so i can bend it in a vice and a hammer :D
