james walker
cooling is the key people
May 24, 2007
5,121
retford notts
hi guys, anyone know the part number for the bolt that goes through the wheel bearing housing to hold the bottom of the strut into it?
bolt and nut numbers if anyone knows.....
cheers guys
good man dave, how quick......
also a quick one, im lowered around 30mm, have a scraping noise that im putting down to either top mounts, arb droplinks etc, do you think the arb droplinks could be catching, its only 30mm though so shouldnt be really should it?
cheers
will do, i think it may be the bottom bolt loose and rotating, going to change the arb links anyway whilst shocks are off to change top mounts...
