Mk4 Fmic
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
Thats strange, you'll buy a very expensive Forge intercooler, you'd expect it to fit just right, but now you can't even mount you're foglights :confused:
I have another question that could be interresting for everybody. I would like to put all temperature logs with all different intercoolers (smic, forge, seat sport, aftermarket universal) under each other so you have a good image of witch cools best.
Keep in mind cooling ain't everything that's important with an intercooler, it's design is very important to keep the final pressure behind the throttle valve as high as possible.
I know there already are some logs available on seatcupra.net but I cant find em all. To begin with I,ve got mine here with the original smic.
Seat Ibiza 1.8 20vt FR remapped @ 214 BHP
Intercooler: Original SMIC
- Old type FR Bumper log 1 - Outside: 19°C - Oil: 97°C - Water: 97°C
- Old type FR Bumper log 2 - Outside: 19°C - Olie: 100°C - Water: 100°C
- Modded Cupra Bumper log 1 - Outside: 19°C - Oil: 97°C - Water - 97°C
- Modded Cupra Bumper log 2 - Outside: 19.5°C - Oil: 100°C- Water - 96°C
This log may not be correct as it is performed by Forge itself.
Seat Ibiza 1.8 20vt FR remapped: No
Intercooler: Forge kit for Ibiza MKIV
Outside air temperature, 16°C - 4th gear run
This log is from user smark32
Seat Ibiza 1.9 TDI PD130 remapped: Yes
Intercooler: Stock smic
Outside air temperature: unknown - 4th gear run
Intercooler: Stock smic - REMOVED FOG LIGHT
This log is from user Damoegan
Seat Ibiza 1.8 20vt Cupra - remapped: Yes
Intercooler: Stock Seat Sport FMIC
Outside air temperature: unknown - Gear: unknown
This is a strange log, as I don't know what scale is used on the horizontal axle. The vertical one shows very low temperatures beneath 35°C
If anybody else could post there logs here would be great.
Jun 21, 2008
673
Wolverhampton
if i was to buy a seat sport intercooler, is there a kit i can but off the shelf for all the pipework etc?
how much do seat charge for the IC and all necessary brackets/pipework etc?
mattydebb123
forge are developing a seat sport style kit apparently its going to be a few months in the making. think its in one of their own threads.
mrcoyote
See no evil...
Jul 26, 2004
2,624
:confused: SeatSport style kit? What do you mean? If you mean a front mount, then it's been out for years. I should know as I had the first ever one when I had my first Ibiza. In fact, it's pictures from my old car on their site...
Breezapom
mk4 ibiza fr 20vt
Jan 12, 2006
608
Hampshire
forge are looking into a new FMIC for the ibiza going to make it similar to the seatsport one as a few people have had some problems with the other one (fitting) which is how i read it?
mattydebb123
from what i understand the new one is going to be larger?? not 100% though. im sure someone will arrive with more knowledge!
Dec 5, 2007
882
Kilmarnock, Ayrshire
I'm going to try fit my tomorrow (with help) and have a few questions.
Do i need to buy any screws to mount the FMIC to the brackets as i didn't get any with my kit
I'm sure i've seen a guide but can't find it ( just read through 11pages here ) anyone remember the link?
nikstar
80
Anyone got a ball park figure on what the dealers are charging for the seatsport FMIC??
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
The Forge pipework doesnt go that high up - so if you buy the Forge pipework and Intercooler, you wont need to that pipe as you dont change that pipe. :)
gus
476
6LL145804 AIR COOLER
6LL145935C PIPE
6LL145832 HOSE
6LL145879 BRACKET
6LL145770 PIPE
6LL145838A HOSE
6LL145834 HOSE
6LL145808C BRACKET
6LL145875A BRACKET
6LL145808B BRACKET
6LL145875B BRACKET
6LL145832B HOSE
are these all the parts i would need to fit the seat ibiza cupra fmic to my ibiza sport????
nikstar
80
Can someone tell me if the pipe work kit forge sells for seat sport IC fits both diesel and petrol?
Conway!
right after reading through all 11 pages i've came to a slight conclusion that just need finalising if someone would be kind enough?
these are the parts i would need to fit the seat cupra fmic to my 1.9tdi 130 sport (53plate):
6LL145935C PIPE
6LL145832 HOSE
6LL145879 BRACKET
6LL145770 PIPE
6LL145838A HOSE
6LL145834 HOSE
6LL145808C BRACKET
6LL145875A BRACKET
6LL145808B BRACKET
6LL145875B BRACKET
6LL145832B HOSE
6LL145808 Mounting brackets
6LL145808A
N90280901 x4 mounting bolts
N90817003 x4
and how much is this likely to set me back??
many thanks conway
