Probably not...........
Try looking at your lon term fuel trims after it has had time to adapt. are they reducing as you go up in maf size?
Was one flow straightener out/in?
Is yours a ko4 or hybrid?
Morning
If your fuel trims are coming into line, then the maf readings are getting nearer to the ones the map was written for. This does not say that the maf is reading accuratey in vag com, just that the values correspond to the correct possitions in the map.
Fuel density does vary a tiny bit, and fpr springs are not absolutely accurate, but i'd expect fuel trims to be + or - 1%or less. This of course only works with no boost or vac leaks.
You need to make sure you're doing multiple logs as well. They need to be repeatable after a few runs to realy get any accuracy. I once got my ihi to read 275g/s on a single log, (effin cold out and cold engine), where it was only repeatable in the 245-250g/s range. You need to ignore single logs.
Personally, I'd chuck the aluminium maf as I don't see what it gains you, stick a standard one on, and then check your fuel trims. It's a lot quicker than all this messing about.
Brand new ones are 70£ exchange from the dealers. Most vag specialists have a few kicking around.
What happened to your original?
£200
Ching.
Im hunting for some mental tubing now. Might be able to get some... So dont stress about!
don't tell them you're not going to exchange, just say you need to take it off the car before you can exchange it. My local dealers charge 20£ untill you return the exchange item (never)
the boost controler if connected right should limit the maximum boost, but let the n75 control the boost up to that level, ie just bleed off over boost.
