jamiebennett81
looking to install a new boost gauge (psi) as I have decided (as cheap and as effective my autogauge is - bar), it could be a better match and I also want to switch to PSI
I want to get an oil temp gauge to match too. Looking at a maximum of £40 per gauge
does anyone know where sells a good match to the spec I am after. Seen a few, but seeing if anyone else can help out
I have a ProSport Premium Electric Boost gauge. It has peak memory & warning functions. Top gauge.
http://prosportgauges.com/amber-white-premium-electric-boost-gauge.aspx
cheers guys
Damoegan, is that easy to wire up, as it has a choice of different colours, does it need extra wiring in as such
also when ordering, it gives you a choice of amber/white, green/white, blue/white :confused:
You want the amber/white one.
Very easy to wire up mate. You just need a switched live, a perminent live and a negative (I took the feeds off the head unit to make it easyer). When you wire it up you either use the white wire or the orange one, depending on what colour you want.
I think they used to go on the bay for less than the web price.
I think you can link them togeather like the Defi ones (there like cheaper copys of Defi gauges). Very smooth operation. Fantastic gauges.
thanks mate
Looking at an oil temp gauge too on that site
You could always sell the other one on the bay if you dont want it mate.
Here are a few vids of when I was testing mine befor I fitted it
nice shoes dude in the second Vid ;)
looking great, but does it beep like that everytime you switch it on, as it sounded really loud?
Rigger boots bud :D I'm an engineer so I need them...
No mate, you can turn it off, I have.
thats good then, thought you might be going clubbing in them!:D
ah ok, thats good then, because that would really start to piss me off after a while
As long as you wire it up propery (ie. with a perminent live (memory)) you can turn the beep off. I did'nt wire it op properly at first and did'nt have a perminent live and the beep evey time I started the car realy got on my tits. So I re-done the wiring and took the feeds from the head unit as its much easyer to distinguish what is what then.
cheers for the help chief;)
