When I first did mine I only did it on the wing and battery sides. Now I have holes everywhere on it!
my theory:
when travelling:
air is pushed into the air box via pressure from the front air feed, the holes allow some air to escape, circulating more air and therefore cooler. the faster your travelling the greater the air flow into the airbox.
I went to McDonalds the other day, and on the way home decided to test my 0 - 60 against the number 36 bus ... and lost(joke)
.G.
Seriously mate get a life, the Number 36 thats the new low floor super green low emissions bus. So due to it having the Newer more efficient engine and the numatic suspension you dont stand a chance!!! PMSLany photos guys??
Your racing bussesSeriously mate get a life, the Number 36 thats the new low floor super green low emissions bus. So due to it having the Newer more efficient engine and the numatic suspension you dont stand a chance!!! PMSL..Get a PD160 come round and ill get my drill out lol
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Do you do this ABOVE the air cleaner element? I assume so or the air will not be filtered. I've got my airbox off at the moment to fit my green panel and maya s well do this at same time. 20mm holes are favourite yes?
The bottom half. When you take the top off and pull the old filter out.... its the bottom bit you drill. Don't do the top bit as the air being sucked in won't be filtered and all sorts of crap would be sucked in to the engine!!! hey guys what will it sound like if i drill the air box out on my 1.4 sport ????![]()
i want to do this drilling idea sounds great!
what do i need to do etc? and where is best to do it?
I have a question
To save me some investigation, maybe someone already knows the answer. when you have an open cone air filter or in my case a drilled air box. Why does it sound so boomy on fast idol when the engine is cold in the morning for 30 secs or so.
There is defo something that seems to be pumping or doing something with the induction to make this boomy sound that I don't much like.
The extra induction sound one warmed up sounds lush and I can hear the turbo wosh and even a little "tish" if you listen hard enough.
What is the nasty boomy noise when cold though ?
i have the 1.9 TDI airbox to the side![]()
