It's probably the seconday air pump that you can hear. It sucks in air from the air box (or not if you have a cone filter
) and pumps it out behind the exhaust valves to make a very lean mix. This increase exhaust temps and get the lamda probes and cat up to temperature quickly so they properly.
I guess if you have a drilled air box, it's sucking this air through the holes and if you have a cone filter, the sound isn't being muffled by the air box.
My air box isn't drilled, I just removed the trumpet. I think it would be too loud along with the Milltek and Forge TIP!
