Just to double check the parts i need ill do the n249 too
007
forge 007p dv
~1m of 4mm silicon hose (for bypass)
If you want to replace that bodged pipe it is around £60 from the dealers, or you could get uprated ones from ths for around £100 for both sides (upper boost hoses) - alternatively, you could use one of the bungs already present to bung t.
forge 007p dv
ok mate well ill bung it for now and get some silicone pipes later on wheres the best place to buy a 007 from forge directly
any of the forum sponsers; not sure if anyone has a deal on them at the moment. DPM performance were cheapest last time I checked but that was a while ago!:)
Thanks one thing you know that bit of red pipe i already got does the t-piece need coming out and the original pipe put back or just bung that red pipe to :confused:
you can just bung the red pipe....or, as you are doing the n249 bypass; take the red pipe off; put your new silicon 4mm pipe on the t-piece and run it to your new diverter valve :)
ahh so its safe for now then right ill get looking for a 007 the hose ebay
yep, but re-block that pipe you took the bolt out of; that is just letting boost/vacuum escape :)
one of the best places for a 007 is awesome, think there price is 10% discounted on Forge RRP, they also sell hose at about £2.50 p/m, combine postage and save more again ;)
i'm being nice because you support BY FAR THE GREATEST TEAM, THE WORLD HAS EVER SEEN :funk:
WEEEYY HEYYYYY COME ON YOU ARSENAL :D thank you very much mate much appreciated
p.s OOO ARSENAL WE LOVE YOU :p
Just an update i got my 4mm hose and forge 007 my question is the bypass do i just remove the old bit of red silicone pipe and join a new piece of 4mm to the t-piece then run that to the top of the 007 :think: as in my wonderful picture :D
It's a bit hard to tell from that picture,
Remove the bung from the TIP and fit the DV there, then put the bung where the red pipe is on the intercoller hose is
ahh thanks mate emm what bout the 4mm is that right what to do in my pic run from the t-piece to the top of the d.v
