dave_chandler
Yeah... I was blind and now I can see!
Glad I went for the H7R bulbs cos they look better to other drivers I reckon,
and nowhere near as much glare.
How hard were the kits to fit? how long did they take?
Yep, definately worth the extra money.
Very simple to fit.
1) Remove back cover of light
2) Cut hole the correct size in the back cover for the gromet which the wires run through
3) Replace halogen bulb with HID
4) Connect wires from bulb to ballest and ballest to old light wires
5) Attach ballest to car
6) Replace back cover
7) Repeat for other side!
Nice and easy then, just presume a bit fiddily to place the ballasts at the sides!
Hi guys, just been on Diane-shop now and im just wondering will these fit my mk4 ibiza. its a 54 plate.. Its got single reflectors so these should cover both beams right? And also another thing why is the price converted to dollars :S when its uk ebay?
PS: Sorry i cant post links i havent made 15 posts
h ttp://cgi.ebay.com/ebaymotors/BI-XENON-HID-CONVERSION-KIT-H4-6000K-HI-LO-DUAL-BEAM_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a1Q7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem45ec2acc05QQitemZ300314971141QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
It depends how neat you want to be...
I removed the bumper to fit the ballasts on the crashbar, routed the cables through the gap under the lights and filed a chunk out of the bottom of the headlight cover (where the seal is) so I did`nt have to drill the 25mm hole in them.
As a result you can`t see the wires going into the back of the lights when you look at them.
Oh yeah, and don`t forget to adjust them after fitting!
I can`t get that to work.
searched it though.. are they the ones from choi-q? If so then they are from the USA, which means the 2-year warranty is virtually useless!
I did`nt drill the hole, i filed a chunk out of the bottom of the cover and made sure the wires fed through it when I refitted them.
you search for it if you remove the http// at the beginning.
I think i read somewhere that they will take the lights no matter where you are or what is wrong as long as it isnt your fault.
Got any pictures? if not where abouts do i have to file the hole?
No I meant I went on ebay and searched the description.
What I meant by the warranty bieng useless is try getting a blub replaced after 18 months when they are in USA!
This is why I buy from the UK if it`s something that can go wrong.
what do you think of these hid's just as a tester.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250424389573
i know they are cheap but they should be good for the time being
That looks ok, from hong-kong but lots of kits are, they do seem to do a HI/LO h4 kit too.
That listing is generic - make sure you buy the HI/LO kit AND specify this when you pay to avoid any c**k ups!
Doing it this way would make a really neat job! Why do you need to drill a 25mm hole? How did you attach the ballast to the slam panel / crash bar?
how long did it take you in total to fit the lighs and re-fit the bumper?
Sorry, just realised I did`nt answer these!
The kits are usually supplied with a rubber grommet which holds the 4 wires together where they go into your light cluster, so most people have drilled a hole in the back of the cover just behind where the bulb sits.
I attatched the ballast using the sticky pad provided and a big cable-tie.
It took me 15 minutes to get the bumper off, 30 minutes to fix the ballasts/ route the cables and 10 to refit the bumper.
Then a few minutes to file the covers down and fit `em.
