I hoped that having the car mapped could potential sort the issue as it may of been a standard map issue or something along those line.
a remap will never fix an underlying problem.
did you mention this to Will before he mapped it?
check the actuator (if) the boost your gauge is actually correct, or simply validate your gauge to a know pressure pump.
If actuator is sticking/split then it wil open slower or not at all, if sticking it would be erraticthe logs dont capture the 28-30psi moments
Just read what you put above, going back to a response from Dave, this seems (2540mbar) to be as high as it will measure so if thats where it's surging/spiking more you won't see it, will you?
Rocky,
Google "TTweakers-Guide.pdf", it is for the TT(same BAM engine i think) but it explains all the blocks that you logged for boost/CF etc... i found it very useful in understanding this stuff.
Have you tried a different n75 Tim?
yes mate, currently running a borrwed n75 but no difference with that either![]()
Well, according to the gauge, i remember one run vividly we hit 28/29 ish, i recall the louder flutter and looking at the boost gauge to check the psi (however i appreciate that may not be the true figure). In fact i'm sure on every run it does it and then to a degree it tails off......
Are there tests for the bold caption?
I have a test pump gauge which I use to pump pressure into actuators etc so I can see their function (sticky or smooth) and also see if they hold pressure or leak, and what pressure they start to move at.
If you electrically disconnected the N75, and or just pumbed direct from charge side to actuator direct you eliminate any such N75 problem, as you have turbo + actuator alone.
If you still get surging then there is something amiss with the turbo/actuator/wastegate itself.
........ i'm going to try and locate a 3 bar MAP sensor, can someone confirm what these are from?
Well i'm ordering the best possible gauge i can tomoz without going into sill money, just so i'm confident or fairly confident it shouldn't read too much different to what i'm actually running, this autogauge one has been nothing but mither so i'm going for a phantom.
As well as this i'm going to look into the wastegate as you say Bill (need to know who can test this though) but also i'm going to try and locate a 3 bar MAP sensor, can someone confirm what these are from?
Well i've decided to ressurect this thread as I've discovered i'm still having the problem. The EGT sensor has been changed, I was given a hint that this could be the underlying issue by Jeff at Awesome as they had an Audi in with the same overboost issue and it was the EGT at fault. As I say the sensor was changed last Wednesday, the car ran at Awesome on Saturday, first time it had been tested shall we say since and it's still hitting 30ish PSI now and again.
