Big figures, there. I'm fairly sure MAFs can over-read as well as under-read, but I'm not saying your figures are wrong.... but much higher than anyone else has ever managed...
However, I came on to post that when I ran the stock airbox plus green filter with a big air feed, in the end I left it with the air feed not connected to the airbox, air feed pointed to the airbox opening but leaving a gap.
I can't remember the figures, but I remember that it is was significant. I felt a detrimental difference in not having pressure in the airbox, but higher g/sec at the top end.
Hot air from the engine bay? Don't really know. Not while you're moving, I wouldn't have thought.
Edit: P.S. a couple of blue leds behind the holes in the sheild, and that would look "bitchin".
LOL @ the blue LEDs
The two sets of logs were run within days of each other so I'm sure they are comparable, but like you say it could be over Reading. I like to keep an open mind.
It feels so different that I'm sure there is a gain there, we will never actually know (because I don't have time to waste to put it back how it was) I'll just try to believe they are correct
phil, working it back from injector duty and rounding down the afr it comes out at 232gs
I've never had idc that high before but if you told me you could gain that much from fitting an air filter, I'd still laugh at you :)
Those maff readings are correct and accurate as your boost levels support the air mass figs.
Can't wait to see what the new filter makes.
The dynatwist cone used as a general cone out of its housing flows poorly compared to the other cones i've tried, but its tapered particuarly narrow to be most effective to allow good flow for air being directed to it from below in a housing. When plumbed to the stock air position the readings were poor also but i've since realised that this area is not presserised at all it just allows the filter to draw cool air rather than be ram fed.
So this week end i will ram feed the dynatwist and then latter get my axe on it and modify it like Probee.
Probee have you seen the Dynatwist XXL considering we are using only the XL version, its rated 100 bhp higher than the XL so must flow better too.
Don't foget that everything is calculated off the MAF when the MAP is maxed out... Not sure about injector duty cycle, though.
Good result, nontheless.
Forgive my lack of knowledge but surely its not all about air flow but the temperature of the air going in the car? No good have lots of air flow if its hot air?
I think this is why Probee hit the jackpot because of his twin cold air feeds from the fog lights feeding his modified dynatwist. Only problem i got with the dynatwist design is the metal used...surely thats a magnet for heat?
That's a good idea, I would like to see how this new filter does first though. It should give better airflow it's a much bigger filter.
Have you got logs of your setup now since getting your SEM sorted? How are you finding it?
I'm not sure how much of a difference it makes as the turbo heats the air considerably and the intercooler does a very good job of cooling and then there's the water injection
It's not the temperature effect of of the hot air, it's that it's lower density.
Once you're moving, the exchange of air under the bonnet, I think, wuold mean that if your car did breath in hot air, it wouldn't do it for long. Plus you have a air feed - it won't ALL be hot air.
on the way back from Deustch Connection show (won best Seat :) and Nick came second, WELL DONE MATE!) today the car felt so strong.... so i nipped in the house and grabbed the laptop then headed off to the hangers for a blast up their straight...
i cant make up my mind if the figures are good or not. it feels rapid for a hot day. but i have got loads of sound equpment in the boot, not to mention dynamat!
outside temp 22.5 running B9 T6
Code:
Sunday	14	June	2009	17:38:09
1ML 906 032 A  		1.8l R4/5VT      01 0001
	Group A:	'066				Group B:	'115
		Speed	Bin. Bits	 	Bin. Bits		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 km/h				STAMP	 /min	%	 mbar	 mbar
	15.88	48	0	 	0	16.3	3560	91.7	2450	1180
	16.7	52	0	 	0	17.1	4440	191.7	2550	2540
	17.5	66	0	 	0	17.9	5520	191.7	2440	2320
	18.3	81	0	 	0	18.7	6280	182	2320	2260
	19.12	92	0	 	0	19.52	6960	160.9	2290	2260
	19.93	101	100	 	0	20.33	6280	13.5	990	1330
	91.92	44	0	 	0	92.32	3760	182	2530	2220
	92.74	56	0	 	0	93.14	5240	191.7	2540	2490
	93.54	75	0	 	0	93.94	5760	191.7	2410	2230
	94.34	85	0	 	0	94.74	6480	191.7	2300	2170
	95.14	95	0	 	0	95.55	5800	115.8	2230	1470
	95.95	101	0	 	0	96.35	5320	191.7	2460	2370
	96.75	110	0	 	0	97.15	5760	191.7	2390	2430
	97.55	119	0	 	0	97.95	6120	191	2330	2300
	98.37	127	0	 	0	98.77	6440	182.7	2290	2250
	99.17	134	0	 	0	99.58	6800	45.1	1000	2540
	99.97	139	0	 	0	100.37	5400	186.5	2440	2250
	100.78	144	0	 	0	101.18	5680	191.7	2410	2400
	101.58	150	0	 	0	101.98	5880	191.7	2380	2340
	102.38	156	0	 	0	102.78	6080	191.7	2350	2320
Code:
	Group A:	'002				Group B:	'118				Group C:	 Not Running
		RPM	Load	Inj. On Time	Mass Flow		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	°C	%	 mbar	STAMP
	58.91	3040	88.7	7.14	53.08	58.51	2920	39	0	1330
	59.7	3400	124.1	10.88	100.5	59.3	3200	38	19.2	1360
	60.52	3960	191.7	18.36	168.47	60.1	3640	38	85.5	2310
	61.32	4520	191.7	18.02	184.25	60.92	4280	37	85.9	2530
	62.12	5040	191.7	17.34	204.06	61.72	4800	37	85.5	2480
	62.94	5520	191.7	17.68	216.36	62.52	5280	37	87.5	2410
	63.74	5960	191.7	15.98	223.33	63.34	5760	39	90.2	2350
	64.54	6320	191.7	15.3	227.94	64.14	6160	39	89.8	2320
	65.34	6640	175.2	14.62	231.19	64.95	6520	42	89.8	2250
	66.15	6800	121.1	7.82	222.61	65.75	6840	44	89.4	2220
	66.95	5480	137.6	15.3	179.78	66.55	6400	44	0	1350
temps are high!
Absolutely awesome result to you both and well deserved.:seatgod:
That car is shifting some air as proved in the turbo pressure flowed at the red line, never have i seen a stock k04 flowing those figures unless the actuator has been well cranked.
The direct feed from the grill is where i'll be feeding my dynatwist from.
are you running a FMIC.
Thanks Carl (spelling?)
Ive read lots about people playing with their actuator but ive always left mine well alone.... its so quick at the minute i keep wondering why im going BT.... i then remember about the cam chain and know im saving money by doing it now. if i get the quotes back soon theres a possibility it can be done before the national meet.
i modified Nicks on Saturday but hes trying to get over boost leaks before he does any logs. im really hoping that someone else gets the same results. it'll be interesting to see if you get the same results with feeding it from the grill.
im running a Forge FMIC... its normally very good at coping with the heat.
Thanks Guys im really chuffed, i have no problem comming second to Aaron! Just glad to get a trofee after all the hard work!!
Going over to aarons wed for a bit of a car + Wii night, hopefully sort out a few problems and get logging.
Well done chaps, as said well deserved!
On another note, going back to the modified heat shield absorbing heat due to being metal... I have the carbon bmc... you can see where I'm going with this... is it worth modifying this in a similar way?? Not sure if I could plant a different filter in there easily though??
This is what I'm thinking too.
Even two feeds to this, one to the side and one in the conventional method
Looked into this with my BMC chaps and not a lot you can do other with the standard filter other than 2 feeds although could fit another filter as Riko says but would think it would be fairly small.... If you pull the filter apart the front section that the feed attachs to is directly moulded the the filter so any holes drilled would be bypassing the filter totally and sucking up all manner of crap. :(
