herb2578
now a cupra owner
Jul 14, 2007
145
west mids
just wandering can anyone help me? i ordered some bushes of ebay for my lc and the seller has come back to me asking what size the front wishbone bush is 30mm or 45mm
i have done a search on here and the net but cant find the info i need
so an answer of here would be much appreciated!!!!
That's a worrying question.
Why not just try the Audi TT roadster ones. There stiff as but still rubber
i have read most the treads about bushes on here and the tt 1 seems to be best but im getting a bush kit probably cause im lazy:redface:
help with what, you said you were going bush kit as you were lazy... end of topic isnt it?
and you just need to buy the kit for mk1 leon.......
i need help with the size of the bush cause i want the item sent to me asap this is the message i got of the seller
Hi Ian,
Thanks very much for you recent order. I just need some extra information about the vehicle before I can process it. I need to know what size the front wishbone front bush is. It would be either 30mm or 45mm. Sorry about this but its new informayion that has only recently come to light.
Regards Rob
so no not end of topic for me cause i need to get back in contact!!
and i did order the mk1 kit!
Hi Ian,
Regards Rob
tbh id stay away from aseller that doesnt know the wishbone sizes.
theres only one size and they fit all the mk4 platform.
just order them from vw spares, and as above go for the tt rear wishbone bush and oem front.
http://www.vwspares.co.uk/product_info.php?products_id=801
http://www.vwspares.co.uk/product_info.php?products_id=252
Febi list the following for their bushes, not sure if it helps any.
Cupra R
characteristics
pack.unit 2 unit
height or thickness 41 mm
inside diameter 13 mm
outside diameter 60 mm
fitting side bottom front axle
fitting side rear
fitting side on both sides
Cupra
characteristics
pack.unit 4 unit
length 41 mm
material rubber / metal
fitting side rear
I had this problem last week, and not with some cheap bush's off ebay but with Powerflex.
They seem to list 2 sizes that can fit the MK1 Cupra/FR, and refer to the 45mm one as being for the later cars.
I have one of the last MK1 FR's so bought the 45mm bush's to find that there is no way it was goin to fit the wishbone and isn't much smaller than the OD of the wishbone itself.
Turns out the 'later cars' refers to TT's.
why are the other ones so cheap £3.50 what are they liquorish lol
You recommend the First ones then the lemforder bushes
I put the lemforder ones on my lc and they seemed a good product, the problem with things like powerflex is they can be too firm and give no movement which can have an adverse affect in the wrong set up, suspension set up is a science of trial and error, aswell as function verses comfort
