How much more help do you want? Too many people want spoon feeding on here
Yep they've got away with havin there nappies changed too much, not by me tho i normally spank that ass til its red raw lmao
Its probably the most simple mod you can do, if you dont understand it an cant/wont take the time to learn about it then its quite simple what you should do, JUST LEAVE IT ALONE!!
just wanna say how nice you all are on here. Am a newbie so didnt know what it does. Didnt search as I didnt think it was a big thing.
Thought forums where here to help? Not to bitch!
The forums here to help you but only if you help yourself. Not searching up on the most common topic on here is not helping yourself so wont get you anywhere on here. We all started off as newbies and our initial message from the admin specifically said to use the search function.
got it pluged in earlyer, came up with somthing to do with 249 which rest, also came up with low fuel running weak or somthing after they reset it started missing and running on 3 cylinders, turns out it wants a coilpack
People on here need to chill, if all the info you ever needed was available by search then there would never be any new threads. If you're so put out by it then dont read the thread and dont reply.
And to answer, it doesnt make a big difference but there is a thread on it as linked by someone helpful who isnt a keyboard warrior.
I agree, i've read a lot of posts on the 249 bypass recently. i also bypassed the n112 without resistors and it put me strasight into limp. I don't recall this being mentioned anywhere. people need to stop biting off the heads of newbs. If you don't want to answer, don't, simple as that! we don't want a reputation as an unhelpful/ratty bunch, do we?
i actually had a good read through all the threads on the n249 tbh most unclear and not very easy to understand but i did read them and nailed it in 10 mins, good mod and no eml pleased with the results:)
agreed there was one pic that really helped me with it cant rember which one now :confused:but in that one looked really simple compared to others i looked at
It's easy to copy the pics that you see BUT if you had a misa-hap as i did, you can't actually see all the pipe runs. for example you see pipes run under the charge pipe or down the back of the block, but where do they terminate?? just saying we ought to be a little easier on our new members, they probably joined for some help.
Its not very hard to work out though is it...
One feed from under inlet mani to a T piece...
Now you have 2 feeds...
One goes to the top of the d/v...
The last one goes to the black and white check valve and then to the n112...
From where i done mine... Click me
If everyone gets fed up of people asking the same question, someone could make a step by step guide with pics and make it a sticky at the top that way the question will never be asked again :)
Until there is a real guide im guessing people will keep on asking
