Who has removed the exterior B Pillar cover?
nph
not very familiar with the terminology but is that the plastic between the driver window and the back passenger window?
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,668
SW LONDON
yes.
i think someone has mentioned this before, believe i read about this when i first had an idea to colour-code mine. think theres 2 torx screws either side but try searching
vroomtshh
4,222
Dreghorn, Scotland
yes.
I did search, but you cant search for 'b' and pillar brings up tons of results. No torx screws on mine that I could see. Seems to be plastic clips. I guess there may be torx screws unders these.
nph
yes, you have to unscrew something. for this you have to pool back a little the rubber which also masks the screws. can give you more details but when my car arrives home i will take a look.
maybe this might help:
nph
sorry for the bad info regarding the screws, mine is with 5 doors and I recall seeing the screws and the pics confirm it.
your assumption is good, etka says that 6=clip lining, so no screws. ;)
seat_rich
Five atoms
Jul 29, 2009
179
If you find a way to get the clips out without destroying everything, I'd love to hear about it!
Tried to remove mine to touch up a bit of rust, and just succeeded in mangling a clip without even managing to remove it :(
vroomtshh
4,222
Dreghorn, Scotland
My plan will be the following:
Phone seat - buy 6 new clips
Use trim removal tool, screwdrivers, pliers, hammer and probably a grinder to remove old ones.
Refit with new clips ;-)
Aimez
that is the only plan that will work, had my rear quarter window replace and the glass man destroyed the two plastic clip screw things when he removed them he put them back in but it looks a bit crap now as one is all bent. Should buy a new one but been like that nearly a year and it is the passenger side so I forget it is there.
