MadsenTDi
54
Denmark
Hello and happy new year on the board :D
I just got my new BI-xenon lights for the leon, but i can see that the xenon ballasters are missing :cry:
Does anybody have the part number for those ballasters, and dosnt mind sharing?
TIA
-Lars
you'll be glad to know I've spent the last 30 mins getting ETKA to work and now I need to update it as I don't have all the SEAT updates, unless someone comes up with it before me, I'll try to get it for you 2moz.
wasn't sure on year/model so checked Leon 1P 06/08/09 and all came back same number
4L0 907 391 Control Unit for discharge bulb
If it helps the same unit is fitted to a few other Seat/Vw/audi
04-09 Altea
09 Ibiza
05-09 Toledo
06-09 Eos
08-09 Passat
08-09 Phaeton
09 Scirroco
07-09 Q7
not listed Skoda/Porsche
04-09 Altea
09 Ibiza
05-09 Toledo
06-09 Eos
08-09 Passat
08-09 Phaeton
09 Scirroco
07-09 Q7
Thanks alot, ive used countless hours on updating my etka, but it just wont show anything for seat :confused:
mines a bit out of date with 7.2/253
just wondered if it was a copy of 6 as they need a different install file to run the different marques
7.0 updated to 622 it says
622 is a VW update.
You need to go into C:\ETKA\prog\
edit these files:
ETKA_SE.INI
ETKA_SK.INI
ETKA_AU.INI
ETKA_VW.INI
and under the header [KONZERN] change the firmen variable to the below:
firmen=VW,AU,SK,SE
Save them all and start ETKA, if you've got the updates in the folder it should then update them all. However you will have a few issues, click the SEAT logo and select maintenance, then INI- Editor, (just ok through any errors) then under the communication header click other communications and untick the checkbox and click store.
Should get rid of most of the problems :)
hi there i did the bi xenon upgrade on my leon fr and i went to a motorfactors that deal with valeo and ordered them from there, the part no is 043731 they are about £70 alot cheaper than dealer and the same just no seat box
622 is a VW update.
edit these files:
ETKA_SE.INI
ETKA_SK.INI
ETKA_AU.INI
ETKA_VW.INI
firmen=VW,AU,SK,SE
Yeeeah, this worked :D Thanks a bunch mate :worship:
As a help to others, a few photos of the ballasters.
The ballast has Valeo part number: 89034934
Hi, you've got more info what do you alle need for oem xenon?
i've got now aftermarked xenon but i want oem xenon
what do i need to order?
the xenon headlights.
balastters
something else ?
thanks
balastters
something else ?
thanks
You also need an adapter-cable from Kufatec.de, and a vagcom to code the car to the oem xenons
Thx
ive i need more info i will send you an pm ;)
you dont have the headlight washers (or how do you say)
and automatic light control unit or do you ?
greets
i have just fitted these also... no headlamp washers or auto levelling tho...
saying that...i have no manual levelling either now :Lol:
Ok thx for the info!
ill go to the dealer and ask about prices
but i already know that the headlights are +- 430 € a pice :(
don't know if the ballasters are inculded because an other price by another dealer was
338 € a pice :think:
greets
greets
Ballasters, bulbs or electric hight adjuster motor are usually not included in price of headlights :( It is a quite expensive mod, if you dont got ebay skills, or a buddy that works at a VAG dealer
