Air Filer extension
Aug 21, 2008
522
Skipton, N Yorkshire
Hi
I am after the size for the silicone pipe I will need to move the Air Cone further towards the wing. At the moment is attached straight to the MAF. I know its 80mm maf as it is a LCR.
I have searched for it but no straight answer (i may just be being stupid tho!! lol)
Any help would be appreciated..
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
so its 100x80mm with no reduction? cheers.
yes this is correct how ever you will need a alloy joiner to. so that you can attach the filter to the new extension piece. this is because the outter diameter of the silicone piece will be geting on for 95mm or close to that. your filter will only fit 80mm
sheffboy
avoiding potholes
May 25, 2007
655
If the outlet on the filter is 80mm then you'll just need a straight 80mm connector to the extension piece then an 80mm connector to the maf.
It all depends on the K&N filter outlet size I suppose.
