Techie thats a beast. So did you actually have a problem with the motor? What was it exactly? If the same things goes on me i'll probably ask them to do the same thing. All seems well at the moment which is fine by me :)
Can you hear the whine until about 3000rpm then the clutch cuts it out as the turbo comes on full boost?
Incredibly hard to do.
I had to change the coupling that drives the supercharger today, I wouldnt wish it on anyone. Took the foam out whilst I was there.
Techie,
Do you think it is possible to get more power by putting a shorter pulley on the supercharger and do a chiptuning accordingly ?
Hi Techie, What was it that made you have to change the pulley!!!,when I accelerate from low revs I get a strange noise which isn,t a "whine" from the supercharger more of a metallic "grating" noise, what could this be !!,is it this clutch mechanism I,ve heard about on here.
Bocawata
Oh right i'll copy and paste some of the info here for you: (Most the info posted is from a guy with a 1.4TSi scirocco with revo stage one, miltec and induction kit).
i was just checking out graham goode racing and saw that they supply a shorter supercharger pulley for the mini cooper s. apparently the mini cooper s and the 1.4tsi share the same supercharger; the Eaton M45.
I am awaiting confirmation of this directly from Eaton as VW service are numpties and were trying to insist that the 1.4tsi only has a turbocharger... idiots.
It is definatley an Eaton but not 100% certain its the M45... that said I REALLY can't see it being the M62...
so... anybody with experience of shortening a supercharger pulley? my simplified understanding of it is that it makes the supercharger spin faster as the gearing ratio is shortened by the shorter pulley, thus providing increased boooooost
anybody heard of any reliability issues i should be worried about or any horror stories???
apparently, on the cooper s, a 15% pulley length reduction can increase power by 15-20bhp and also torque by the same ratio, and bring boost in sooner. See link for source: http://www.mini-madness.com/madness-min ... ulley.aspx
however, as with everything about the 1.4tsi, this isn't a simple matter as there is the small factor of the 3000rpm cut-off to take into account...
unfortunatley, don't get your hope up too much! even if the superchargers are the same (which i'm 95% sure they are), the cooper s pulley set is not a direct swap parts (shame as it would be the best £115 i've spent recentley!) as obviously mounting positions are different etc. however, it may be an interesting avenue to venture down... i know i'm gonna do a bit more investigating
any mech/tech guys, please lay down your thoughts!
right so let me outline todays findings.
first though, see transcripts for emails sent between myself and a very helpful person at Eaton called Kaid:
________________________________________
Sent: Tuesday, December 15, 2009 7:49 AM
To: Marshall, SuperCharger
Subject: Which supercharger is fitted to...
Hello
I was hoping you could help me with a quick piece of information...
Which model supercharger is fitted to the Volkswagen 1.4 TSI “Twincharger” engine?
Also, could you confirm that the M45 model supercharger is fitted the 1.6 Mini Cooper S?
Thanks,
Patrick Firmager
Sent: 15 December 2009 15:22
To: Patrick Firmager
Subject: RE: Which supercharger is fitted to...
Hello Sir,
The 1.4L TSI engine uses an Eaton M24 supercharger specifically designed for VW. It is unique as the design incorporates step gears to change the drive ratio within the supercharger. Also you are correct as the M45 is the unit that is used in the 1.6L Mini Cooper S.
Best regards,
Kaid
Sent: Tuesday, December 15, 2009 10:33 AM
Hi Kaid
Thanks for getting back to me, much appreciated!
Why does the 1.4TSI use an M24 instead of an M45, and why does it need to have step gears to change the drive ratio?
Cheers,
Patrick
Sent: 15 December 2009 15:34
The goal of the ”Twincharged’ engine was to use a supercharger to create boost at low engine RPM while the turbo charger was still trying to reach efficient rpm from exhaust gas. A faster rotating M24 was smaller in size and provided more efficient airflow than a slower rotating M45. The step gears allows the M24 to rotate towards maximum RPM at only 3500 engine RPM. Without the step gears the pulley would be much too small to fit on the shaft and would not have enough area for the belt to contact.
Regards,
Kaid
Sent: Tuesday, December 15, 2009 10:49 AM
Ah I see. Just a couple more things, sorry to be a pain...
My understanding is that the supercharger connected to the 1.4 TSI cuts out at between 3000-3500rpm via the use of an electromagnetic clutch.
What is the peak boost and maximum RPM of the M24 at 3000-3500rpm? What is the maximum recommended operating speed and boost of the M24 supercharger?
I am trying to find some way of improving the performance of the supercharger on the 1.4TSI and the traditional methods (fitting a smaller pulley and belt to increase supercharger speed and thus boost) to seem to be viable at the moment... any thoughts/ideas?
Cheers,
Patrick
Sent: 15 December 2009 15:58
The maximum speed at the pulley is 9000 rpm (rotor speeds at 17370) due to the internal step ratio of 1.93. I do not know the theoretical boost at that speed as that is a function of the engine system. I do know that the unit will flow 360 m^3/hour at 1bar gage pressure, 17370 RPM. 1 bar gage pressure at STP is the maximum validated pressure for this unit.
I do not know the pulley to crank ratio so I am unsure how fast the unit is rotating when it disengages at 3500 rpm…
Regards,
Kaid
So what have we learn't?
1) after pouring over many sites and reviews, a roots type supercharger is terribly inefficient... it runs at about 60% efficiency as apposed to a twin screw which is around 90%. this leads to an excess builup of heat which makes the extra air your forcing into the cylinders less dense... which is bad for power production. see link for a detailed comparison of heat (albeit i think it may be slightly bias :S) http://www.kennebell.net/techinfo/gener ... atalog.pdf.
2) basically, a twin screw type supercharger would be much better. after going over a few websites, the winner appears to be a charger produced by lysholm, a subsidiary of opcon (see http://www.opcon.se/index.asp?sPage=1&langID=2&cID=14 for product range). i've not got as far as pinning down which model would best suit the 1.4tsi... i have a feeling it won't be as simple as using the usual manufacturer's recommended approximate engine capacity to charger size charts...
3) doing it on the cheap, a smaller pulley and shorter belt would probably work; albeit it hasn't been developed yet and i'm struggling to find anyone with enough expertise/experience/interest in this type of thing to wanna try it out. also, from my link to kennebell.net above, around 12psi will heat the air to over 250degC... which again is bad. HOWEVER! there is a saving grace! the 1.4tsi comes equipped with a handy dandy intercooler which would help to drop those temperatures significantly, more so if (like me ) you have a Forge front mounted intercooler installed too. also, having read a fair bit, whenver the cooper s' went for a smaller pulley and belt, the spark plugs were recommended to be changed to cooler NGK iridium plugs. this was to detonation or worse... the plugs melting :S. On top of all this, many were recommending water injection and spray bars to further try and cool the charged air. oh by the way, the maximum operating pressure of the M24 is 14.5psi (also known as 1bar)... just imagine the charge air temp and that boost arghhhh!!!
4) if you can spare the money and the heartache, a twin screw supercharger conversion would probably be a better plan. the only problem being that:
a) it is totally unmarked territory
b) the twin screw's are more expensive
c) they have a slightly shorter lifespan and VW sure won't be servicing them...
d) no clue how the electromagnetic 3500rpm cut-off clutch is implemented so again, no idea how you connect the two componants together.
e) boring stuff like engine bay location and mountings have to be addressed. also the supercharger is a b****** to get to as its under and behind the engine (i think...)
f) unsure which model twin screw is suitable.
at least you would recieve the same kind of power delivery as at the moment, as the whole point of the 1.4tsi is that the supercharger gives that direct "hit" of power and torque to get you by as the turbo spools up. this is why a roots supercharger has been used, a centrifugal stlye charger, such as a rotrex, has power delivery which increases with engine rpm, meaning you have bugger all low down the rev range... twin screwsuperchargers also give immediate boost.
final summary, you have two choices if you wanna improve your supercharger:
1. keep roots style eaton m24, get smaller pulley and belt developed, install a front mounted intercooler (and maybe a spray bar), replace spark plugs with cooler iridium type ones, alter vehicle mapping to make use of extra air.
2. replace charger with twin screw style lysholm model, get just about everything involved with adding a supercharger to an engine developed for this application, alter vehicle mapping to make use of extra air.
So yeh... an thoughts?
which would you go for? actually on second thoughts, lets have a vote!
"wigit wrote: you shoved your car on a dyno yet pat and run stock/revo runs to benchamark the diffrence given the dyno lottery, outfit who did mine were pretty good in mk"
yeh had it done before i had the intake and intercooler done... managed 208bhp with ambient temp of 35degC. i know your not supposed to quote corrected figures but on a cold day (ambient temp of 5degC) they reckoned it wud make 218bhp.
getting it dyno-ed at awesome-gti in the new year when the full exhaust goes on though! shud be fun just gotta wait for that damn scirocco R rear bumper to come out so they can get the backbox tailpipe spacing right.
oh btw, anybody fancies checking out the lysholm range (and frankly you'd be weird if you didn't want to ) visit http://www.opcon.se/index.asp?sPage=1&langID=2&cID=14
"I had a Cooper S before the roc. I fitted this with a pulley, belt, sparkplugs, airfilter and bluefin.
It went from 160hp to about 210."
No need for extra cooling.
But after about 6 months the bearings in the charger started to make weird noises, so i sold the damn thing:p
yeh i saw this kit on graham goode, its what got me thinking in the first place.
if you change the pulley and belt for one thats smaller and shorter, you increase the number of revolution the charger does which means that yeh you get more power, but the lifespan of the charger decreases as its putting more stress on the bearings as they are being used more...
would probs benefit from something like ceramic bearings maybe? nice and expensive i bet...
with almost all mods you will have either decreased componant lifespan or increased fuel consupmtion, or both...
That is most of the relevent info. There is some talk about the old cooper S which used a Supercharger and the mods which were done on that.
