Catch tank fitted .....eventually
Jul 29, 2006
723
cumbria
www.facebook.com
Finally got some pics up of the new catch tank fitted,all seems well so far.
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
cowie, what does the tank sit on? also can you show more pics of where the pipe is attached (back of engine bay). is there a t-piece in blue and what is it attached to?
thanks.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Looking good mate.
thanks.
Sal, the one at the back goes to the tip where the old breather pipe went and the "T" piece goes to a plastic fitting that goes into the block, remove the inlet cover and look down its next to the oil filter housing.
Jul 29, 2006
723
cumbria
www.facebook.com
Here's som pics of where the pipes connect to
This is where the pipe was Teed off down below the manifold.
A couple of pics of the elbow going into the TIP,i have removed the 'black mushroom' accumulator valve.
Sal,the catch tank has a bracket and i have just bolted it to the side of the battery cover.
james,if you mean by PCV removed,i have removed the black'mushroom' accumulator valve.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
i ment have you removed your pcv valve thus eliminating the weak part of the vac system under the inlet manny, but from the first pic i can see its still there.. why the need to remove the accumulator check valve mate?
Jul 29, 2006
723
cumbria
www.facebook.com
Hi mate,I think I only removed because of reading it in some part of one of the catch tank threads,that there was no need for it as such now,as the catch tank was doing the job :shrug:
I haven't removed the pcv valve mate,was hard enough getting to undo the impossible oem clip to plumb that elbow in down there.Are there any good clear pics of this valve,and possible removal of it knocking about on here?
What size is that T piece mate?
That piece showing is an elbow Adam,that and the Tee piece are both 19mm.
james walker
May 24, 2007
5,121
retford notts
James did you have much of a fight getting to the PCV valve mate? looks a nightmare to me,looks like i've only done half the job then :cry:
havnt done the catch tank mate, but i would remove the pcv valve yes... will be tight under there, look into removing inlet manny to make life easier....
pcv valve itself is a weak point in the system prone to fail, so replacing with silicone is a good move
