a think a seen ur reg at ek cruise
lol yea i think i seen your car there...looking good. like the plate??
what happened when your turbo went? think mine has just gone, its just putting out a hell of alot of smoke and the turbo isnt spooling?
yeah loads of white smoke
Spotted you today on Paisley Road West at 12:20 today, making a "spirited" get away from the cash line...
I was crossing the road, nearly died from the industrial revolution puring out the back of the car!
.G.
I've bought the allard egr delete kit, anyone recommend where I should put the delete steel plate?
Xheers
On the turbo I would!! Keeps pressure in the turbo, saves it travelling all the way up to EGR to find it cant get through....
Cheers,do you think I should buy an extra delete to put at the end where it goes up into the throttle body?
Otherwise would it not just be left open,I know obviously nothing will be flowing through it but just curious?
The allard pipe doesn't have a place for the egr pipe to connect to it gets rid of it. You put the blanking plate on the exhaust manifold where the old egr pipe connected too, you then remove the old egr housing of the manifold, and put the allard pipe on, this gets rid of the egr all together.
Ah yeh - it does!![]()
I'd get all custom charge pipe made up too and convert it all the silicone. I got rid of 99% of my standard IC pipework setup and replaced it with custom and silicone.
remember our egr has the cooler so it is water cooled...can't remove that alltogether...if so how?
