Aiming for the Masses - Uzi's 305BHP Mk4 Ibiza Cupra TDi (MODs & Pictures on 1st post
Aug 6, 2009
969
cumbria
what happened when your turbo went? think mine has just gone, its just putting out a hell of alot of smoke and the turbo isnt spooling?
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Sounds like the turbo has gone to me! White smoke indicates turbo blown. Black smoke indicates boost leak. :) Blue smoke means burning oil obv.
Chris_B
Is it white smoke?
I was in my brothers Audi S3 when his turbo went and it threw out a load of white smoke.
Jan 28, 2009
703
Glasgow
yeah loads of white smoke
if its white smoke and a lot of it then sounds like ur Turbo,first time when mine went I had a huge flame out the exhaust followed by a huge amount of black smoke followed by white.second time car was not boosting and I just had a heck of white smoke come out....first time my Turbo literally destroyed,and the second something went through it destroying the exhaust side of the Turbo.
gulzar
LCR jabba'd
Oct 1, 2007
178
turbo going can be white or blue smoke, blue smoke indicating oil more so.
gulzar
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
Spotted you today on Paisley Road West at 12:20 today, making a "spirited" get away from the cash line...
I was crossing the road, nearly died from the industrial revolution puring out the back of the car! :lol:
.G.
Jan 28, 2009
703
Glasgow
.G.
lol, yea i was in a hurry, was late for work. a few people have said its more smokey than what it used to be....hmm was it bad or quite normal??
Jan 28, 2009
703
Glasgow
On the turbo I would!! Keeps pressure in the turbo, saves it travelling all the way up to EGR to find it cant get through....
Cheers,do you think I should buy an extra delete to put at the end where it goes up into the throttle body?
Otherwise would it not just be left open,I know obviously nothing will be flowing through it but just curious?
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Like you say - there'll be nothing going through it so shouldnt be an issue. If it was deemed necessary, I'm sure both Allards and other companies that make them would supply two. :)
georgebibizafr
137
Cheshire uk.
The allard pipe doesn't have a place for the egr pipe to connect to it gets rid of it. You put the blanking plate on the exhaust manifold where the old egr pipe connected too, you then remove the old egr housing of the manifold, and put the allard pipe on, this gets rid of the egr all together.
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Ah yeh - it does! :D
I'd get all custom charge pipe made up too and convert it all the silicone. I got rid of 99% of my standard IC pipework setup and replaced it with custom and silicone.
Jan 28, 2009
703
Glasgow
thats what i have planned. the allard pipe is 57mm so i need to order up the right silicone hose, do you know what size the aluminium pipework is where the 90 degree standard hose connect from to go to the egr?? i have a feeling it is the same but not sure??
Jan 28, 2009
703
Glasgow
remember our egr has the cooler so it is water cooled...can't remove that alltogether...if so how?
georgebibizafr
137
Cheshire uk.
O yeh you have a pd150 engine, although 160bhp in the cupra, my engine hasnt got one i don't think,(pd130) just straight from the exhaust manifold to the the inlet manifold, You can get rid of it all together, i'm not 100 % but id imagine it just has two coolant hoses going to a heat exchanger, can you not unbolt the cooler, and just but a straight connecter in and connect the in and the out coolant pipes of the cooler together, and then you could get rid of it all together, just put a blanking plate on the turbo manifold then.
