CUPRA :)
This is what im after next, can i ask how much the uprated Turbo was? did you notice much difference from stage 1 -2? Ta
Alrite Josh hows the car going mate? Will need to see this when the hybrid goes on its a route im thinking of going down myself after the summer just dunno if it will be worth the extra money for a sake of 40 odd bhp![]()
I've been on his case about this too.Who are you going to get to map this little puppy once fitted then mate?
The group he had told me about I'm trying to change his mind over but we will see what his current favourite is.
No point in doing this then not having it mapped correctly to make the most of the benefits of his full set up.
This has to be a full custom to make it worth while, or else a certain Red KO3S'd Ibiza Cupra will make him look silly
Josh, the biggest risk is between having the turbo fitted and having it properly mapped.I have a mapped ecu by Jabbasport for it at the moment, which will be fitted and then tweeked to suit my car just to get it running safely.
Then if money is going well maybe I will get it properly mapped to its full potential with a set of uprated rods to go with it.
Willie if I do go ahead and get it mapped maxed out I'm just going to bend the rods, if not I will always be driving it in fear of doing it.
I drove mine on Revo Stg 1 code ~40 miles over to Bill, just made sure I was off boost.
If you can't trust your right foot just disconnect the N75, but a full custom map is the only way to go to get the most out of these setups (with rods)
Is upprated rods a must when going hybrid (cr-turbo)?
Prebs
