Eyelids - Yes or No see post#64
  • Total voters
  • Poll closed .
My front wishbone bush went aswel last month.. not hard to fix i just bought one from morrisons and got a guy to fit it down at cannalbank all in all £40 .
To be honest not sure when I'm going to be able to do it, i'm moving house at the end of the month and the car still needs to be MOT'd, also going to Norway for a weekend... :cry:
I will however be buying the Cupra bushes and having them fitted.
.G.
Nice little route that mate.
What phone you got? if your using a Nokia, use Nokia Sport tracker, it is sick! I use it for most of my rides and it's cool to see all the stats.
I use an HTC Hero with Google My Tracks - which is essentially Google Maps with tracking and stats. When I upload the track the stats get punted into Google Docs as a spreadsheet (yawn, yawn, yawn)...
On the phone it gives me 3 screens; the map - with track, a elevation/speed graph, and a list of all speeds and distances... pretty good fun tbh...
.G.
Dark blue helmet / (weather dependant) light blue kagool, bright yellow or red t-shirt...
Ride in a big hurry everywhere....:D
.G.
well the guy i seen was crossing the road in front of my bus wearin a dark blue t shirt. was good weather. maybe your twin lol
Got up at 4am on sunday morning to go and stand at the edge of this...
18/06/2010 - Added my own images now...
Preikestolen, also known by the English translations of Preacher's Pulpit or Pulpit Rock, and by the old local name Hyvlatonnå, is a massive cliff 604 metres (1982 feet) above Lysefjorden, opposite the Kjerag plateau, in Forsand, Ryfylke, Norway. The top of the cliff is approximately 25 by 25 metres (82 by 82 feet) square and almost flat, and is a famous tourist attraction in Norway.
.G.
So This is my bike....
I've had it for 9 years now and recently things have started to go wrong... so I took it to Dales for some repairs... £265 later...
Parts list...
  • HG50 (11 -32) 9 Speed Cassette
  • PC951 SRAM Chain
  • UN54 BS 73-113mm Square Bottom Bracket
  • S3 Silver Sealed Headset
  • Chain rings cleaned
  • Hub Service
  • 1 Pack Bearings
  • Cone RHS XT/LX/Deore Freehub
  • 6 x Outer SP41 for 1.2mm Cables
  • 2 x Inner 1.2mm Cables
  • 36 x Silver Spokes
  • SG351 Wheel RIM
  • 1 Pack of Brass Nipples
  • Labour £40
Work carried out...
  • Fitted new chain and cassette
  • Cleaned chainset and both mechs in parts washer
  • Fitted new bottom bracket as old unit was worn with play
  • Reset gears front and rear
  • Fitted new inner gear cables and outer rear cable fitted
  • Fitted new headset as old unit was worn out
  • Serviced rear hub as the axle was badly bent
  • Fitted new RHS cone and 1/4" bearings
  • Rear wheel hand built
I get the rear wheel back on Thursday after it was been rebuilt, the rebuild with all new parts apart from the hub and axle is about £80 inc. labour which is about £20 less than a new wheel!
I thought cars where expensive!! :lol: Hopefully this list of parts should last about another 9 years... :confused:
.G.
just needs a sound system and some coilies mate :D
